02-06-2019 11:25 PM - edited 03-08-2019 05:16 PM
I had 2 macs ( ipphone+pc) connected on same interface on cisco switch both configured as sticky and maximum 2 as below:
int g1/0/3
switchport port-security
switchport port-security max 2
switchport port-security violation restrict
switchport port-security mac-address sticky
the issue is Ip-phone works fine but pc couldn't get ip address related to violation , could anyone recommend troubleshooting commands to solve this ??
Solved! Go to Solution.
02-07-2019 12:13 AM
I will do standard as per cisco guidelines
switchport access vlan XXX <<-- data
switchport mode access
switchport voice vlan ZZZ <-- voice VLAN
switchport port-security maximum 4
switchport port-security aging time 5
switchport port-security aging type inactivity
02-06-2019 11:36 PM
Have you tried "switchport port-security max 3"?
John
02-07-2019 12:13 AM
02-07-2019 12:33 AM
problem is solved when I put maximum 4 , but I need to understand why we put maximum 4 ?
02-07-2019 06:20 AM
Sets the maximum number of secure MAC addresses for the interface - I do safe side 4 MAC Address.
For example : Phone, behind Phone PC ( may be users running some vm also in that PC, so give some flexibility.
