Port-Security not incrementing Violation counters??
bprinski
Hello, My switch is logging port security violations but when I look at the counters it is not incrementing?
May 7 07:07:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 07:16:27 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 07:28:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 07:43:27 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 07:49:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 07:52:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 08:07:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 08:40:27 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 08:46:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 08:49:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 7 08:52:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 8 00:17:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 8 00:35:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
May 8 01:26:30 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0011.85ba.63f6 on port GigabitEthernet5/22.
Switch# sho clo
01:42:52.508 UTC Thu May 8 2008
Switch# sho port-security interface g5/22
Port Security : Enabled
Port Status : Secure-up
Violation Mode : Restrict
Aging Time : 2 mins
Aging Type : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses : 1
Total MAC Addresses : 1
Configured MAC Addresses : 0
Sticky MAC Addresses : 0
Last Source Address : 0011.85ba.63f7
Security Violation Count : 4
tstanik
Level 5
Level 5
If a machine moves ports, but the old port is not cleared. Mean if you turn off port security and the mac-address sticky on the old port, it will allow you to "unlock" the new port and grab the stick address without restricting the new port. Once the new port is live, you can turn port security back on the old port.
