Port-security, storm-control and bpduguard - redundant?
ivarstrandberg
Hi.
In an effort to get more control over our office network, we have configured port-security (default settings, but with "violation restrict"), to prohibit users from connecting more that one device on an access port.
If someone should connect an unmanaged switch, and make a loop on that switch, would port-security be enough (since it stops traffic from all MAC addresses learned on that port, except the first MAC address), or would we need storm-control as well?
How about bpduguard? Is that necessary?
Here's an example:
interface GigabitEthernet1/0/1
switchport access vlan X
switchport mode access
switchport port-security
switchport port-security violation restrict
storm-control broadcast level 10.00
storm-control multicast level 10.00
spanning-tree portfast
spanning-tree bpduguard enable
end
Kind regards,
IS
Rolf Fischer
Level 9
Level 9
if you want to prevent from bridging loops effectively, you should use BPDUguard on your edgeports.
Combining that with port-security and/or storm-control is wise, but you have to keep in mind that they cannot avoid loops. Strom-control can lessen the impact of a loop but maybe you should try to find meaningfull values which meet your requirements. I think 10% broadcast on a Gigabit edgeport is by far to much.
Best regards
Rolf
Will BPDUguard help even if the switch the user connects doesn't support STP?
Will the Catalyst see its own BPDUs if there's a loop, and then shut down the port?
When it comes to storm-control, what percentage range would be recommended on a gig-port?
Is it necessary to storm-control multicast as well as broadcast?
/IS
Yes. BPDUs are layer-2 multicasts and a unmanaged or Not-STP-aware switch will flood them back to the Catalyst in such a case.
If a bridging loop occurs, yes. Here, the combination with port-security can be useful to identifiy such ports.
There are not really recommendations for storm-control values, what's "normal" allways depends on the specific network, applications, etc.
I think you can safely start with 1.00 and then approximate to adequate values for your environment.
Don't exaggerate, you don't want to experience lots of "false positives".
Hope that helps
Rolf
Andrew Devine
You need to be careful with this configuration.
Violation restrict will not shutdown the port, and can potentially block the BPDUs hence bpduguard will not kick in and you will create a loop.
Better to use "switchport port-security violation shutdown" to avoid loops.
