06-07-2015 07:21 AM - edited 03-08-2019 12:26 AM
Hi everybody!
thank you for taking time to help me!
i want to know if this switch "Cisco Catalyst 3560X-48T-S" contains " SFP combo ports" and how many.
i also want to have a document with technical specifications of this switch.
thank u every one
Solved! Go to Solution.
06-07-2015 10:26 AM
That is most commonly implemented using the "10-Gigabit Ethernet
C3KX-NM-10G" but you could also use the "10-Gigabit Ethernet Service module
C3KX-SM-10G" model to additionally add Netflow and Macsec capabilities.
As noted in the guide I linked earlier, the first one "...has four slots. Two slots support only 1-Gigabit SFP modules, two slots support either 1-Gigabit SFP or 10-Gigabit SFP+ modules.". The second has two SFP / SFP+ slots.
06-07-2015 09:13 AM
The ports depend on the type of network module installed (including the blank network module which has no ports).
Please refer to the hardware installation guide for complete details.
06-07-2015 10:16 AM
Thank you for your answer!
I have not yet bought the switch but one of my customer asked for a switch containing 4 SFP Combo ports.
So, in which one of te compatible network module can i find these combo ports???
Thank u for all.
06-07-2015 10:26 AM
06-07-2015 10:44 AM
Thank you very much
