Power over Ethernet Trap
klnnnnng
Hello community,
I am managing a lot of C9300 switches and the PoE demand is increasing, so I was trying to implement SNMP trap notification when the PoE Remaining power (Watts) is below 20% of the switch power budget. Unfortunately, I don't see the expected SNMP traps/OID and I was wondering if anyone has successfully configured PoE threshold and trap notification?
Configuration:
snmp-server enable traps power-ethernet group 1 threshold 80 (%)
snmp-server enable traps power-ethernet police
Any tips would be appreciated.
marce1000
  - I would advise that you also check the current software version on the switch and check the issue
    against  the latest advisory release (upgrade if needed) ,
 M.
