prefix list problem
sarahr202
Level 7
Level 7
Hi everybody
Please consider the following example:
rest of network------f0/0-R2- f0/1---------------------R3
R2#show ip route
C    200.200.200.0/24 is directly connected, FastEthernet0/1
C    199.199.199.0/24 is directly connected, FastEthernet0/0
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D       10.0.0.0/8 [90/409600] via 199.199.199.1, 00:02:59, FastEthernet0/0
C       10.1.0.0/16 is directly connected, Loopback1
router eigrp 1
network 10.0.0.0
network 199.199.199.0
network 200.200.200.0
distribute-list list out FastEthernet0/1
no auto-summary
ip prefix-list list seq 5 permit 10.0.0.0/8
This is what my book says about prefix list above:
Without ge or le configured, both prefix ( 10.0.0.0) and prefix length ( 😎 must be exact match.
Based on the above statement, prefix 10.0.0.0/8 should be the only prefix permitted out of f0/1. The prefix 199.199.199.0/24 and 10.1.0.0/16 do no match the above prefix list and thus should not be advertised as per configurations.
However when I check the routing table at R3, I found prefixes 199.199.199.0/24, and 10.1.0.0/16
R3#show ip route
C    200.200.200.0/24 is directly connected, FastEthernet0/0
D    199.199.199.0/24 [90/307200] via 200.200.200.2, 00:10:51, FastEthernet0/0
D       10.0.0.0/8 [90/435200] via 200.200.200.2, 00:10:51, FastEthernet0/0
D       10.1.0.0/16 [90/409600] via 200.200.200.2, 00:10:51, FastEthernet0/0
I appreciate your help
thanks and have a great weekend.
2 Accepted Solutions
Reza Sharifi
Hi Sarah,
Can you attached that to an access-list instead of prefix-list:
see my example:
router eigrp 1
network 10.0.0.0
distribute-list test out GigabitEthernet0/0
no auto-summary
ip access-list standard test
permit 10.0.0.0 0.0.0.255
Now if you go to R3 and do a "sh ip route eigrp" you should only see the 10.0.0.0 subnet.
Reza
Hi Sarah,
When the prefix-list does not have le ge at the end of it, then it is an exact match.  So, in your case you are right 10.0.0.0/8 is an exact match and if you are denying 10.0.0.0/8 than 10.1.0.0/16 should be allowed:
I have include an example using prefix-list with eigrp before the prefix is applied and after:
before:
Switch#sh ip route eigrp
D    199.199.199.0/24 [90/2816] via 10.1.1.1, 00:00:01, GigabitEthernet1/0/47
     10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
D       10.0.0.0/8 [90/2816] via 10.1.1.1, 00:00:01, GigabitEthernet1/0/47
D       10.1.0.0/16 [90/2816] via 10.1.1.1, 00:00:01, GigabitEthernet1/0/47
Switch#
As you can see 10/8 is in the routing table and so is 10.1/16 and 199.199.199/24
here is the prefix list config
ip prefix-list test seq 5 deny 10.0.0.0/8
ip prefix-list test seq 10 permit 0.0.0.0/0 le 32
router eigrp 1
network 10.0.0.0
distribute-list prefix test out GigabitEthernet0/0
no auto-summary
R2(config-router)#
and the result is that 10/8 is not in the routing table any more :
make sure to clear the eigrp neighbor first before you look at the routing table again
Switch#clear ip eigrp 1 neighbors
now
D    199.199.199.0/24 [90/2816] via 10.1.1.1, 00:00:03, GigabitEthernet1/0/47
D       10.1.0.0/16 [90/2816] via 10.1.1.1, 00:00:03, GigabitEthernet1/0/47
Switch#
Reza
9 Replies 9
pardeep_verma
Community Member
Hi Sarah,
Can u share ur configuration for router-2 & 3
With Regards
Pardeep Kumar
( Rate please if it is helpful )
With Regards Pardeep Kumar ( Rate please if it is helpful )
R2#show running-config
Building configuration...
Current configuration : 1209 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
interface Loopback1
ip address 10.1.1.1 255.255.0.0
interface FastEthernet0/0
ip address 199.199.199.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 200.200.200.2 255.255.255.0
duplex auto
speed auto
router eigrp 1
network 10.0.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip access-list standard list
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2#
R3
R3#show running-config
Current configuration : 976 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
log config
  hidekeys
ip address 200.200.200.3 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
auto-summary
no ip http server
control-plane
!line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R3#
thanks
Hi Sarah,
Did the solution work for you?
Reza
Reza Sharifi
Hi Sarah,
see my example:
router eigrp 1
network 10.0.0.0
no auto-summary
Reza
Hi Reza.
I  have already learned how we can use distribute list to control routes in updates using access-list or route map.
The third option we have is to use ip prefix list and referenced it in distribute list.  So this is what  I am trying to understand.
The first thing I need to understand the how  this ip prefix list command works.
Ip prefix list has many options such as le ge  etc. I am still trying to understand how the ip prefix list works when none of this option is  used. For example  ip prefix-list lee permit 10.0.0.0/8
Book says prefix with the exact match and prefix length will match the above. For example
10.0.0.0/8  will match the prefix list lee but 10.1.0.0/16  will not.
However, When I put this book 's claim to test, I found 10.1.0.0/16 still permitted out of int f0/1 of R2. I was expecting since 10.1.0.0/16 does not match the prefix list 10.0.0.0/8, therefore it will be denied by implicit deny statement under ip prefix lee and therefore R2 will not be advertise this prefix to its neighbor R3.
For some reason, R3 is learning this route, and also 199.199.199.0/24
This is what I am trying to figure out.
thanks and have a great day.
Hi Sarah,
before:
Switch#
router eigrp 1
network 10.0.0.0
no auto-summary
R2(config-router)#
now
Switch#
Reza
Thanks Reza.
In my example, there is an implicit deny at the end of ip prefix list so 10.0.0.0/8 is allowed but all the rest i.e 10.1.0.0/16, 199.199.199.0/24 should not have been advertised to R3 because of implicit deny.
I think this is the bug in ios .
this is correct but not an answer to the original anomaly (-:
Can you check that you have the prefix keyword in your eigrp config for the filter as it's in Resa's example but not in the config above.
