Prevent multiple devices on single interface
Michal_546897
we have Cisco CBS250 series switches.
We deployed them recently with 802.1x
Unfortunately I found out that it is still possible to have multiple devices connected to single interface via unmanaged switch if authenticated computer is connected to the unmanag. switch.
How do I prevent this behaviour ?
This is sample interface config :
interface range GigabitEthernet 1-36
switchport mode access
switchport access vlan 1
dot1x port-control auto
dot1x guest-vlan enable
balaji.bandi
If you do not want any other device connection behind the port, then use host most.
most cases people have Phone and PC connected to same port.  if you have only 1 PC then check :
dot1x host-mode
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-250-cli/802_1X_Commands.html#wp3356823295
BB
Mark Elsen
 - Look into using port security as explained in :
               https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2944-demonstration-port-security-default-changes.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
