11-10-2012 07:06 PM - edited 03-07-2019 09:59 AM
Currently Being Moderated
We are having a problem with our Xerox 5745 multifunction Printer...
This problem had been forwarded to Xerox, but they claim that a problem was caused by a power surge on our Cisco router.
We are having a total of 8 CiscoCatalyst 2960 Series in our IT Communication rooms.
We are also having 2 Xerox 7120, 4 Xerox 5745, 6 HP5200 and 300 computers - PC (HP Desktop) and Laptop (Samsung).
Network : all connected to CISCO Catalyst 2960 Series
Printer Setup:
IP Address: Manual IP Assignment (DHCP Disabled)
PC Setup: TCP/IP –RAW on Port 9100 – SNMP Status ENABLED
The two machines has same firmware software and configuration settings.
one machine just been installed with latest firmware
Problem:
On 3 Xerox 5745 display panel shows: "Network Controller booting"
at 75% the system restart and go on again and again.
This happens when cables are connected to CISCO Catalyst 2660.
Testing done:
HELP! Please ...
Solved! Go to Solution.
11-10-2012 11:38 PM
Ferdinand,
at least you're not the only one who's experiencing this problem:
http://forum.support.xerox.com/t5/Hardware/Workcentre-5135-network-controller/td-p/5086
http://www.fixya.com/support/t556616-network_controller_unavailable (read the comments too!)
In case of your c2960 supports PoE, did you test to disable power inline (I know, PoE normally can't be the reason - but this is a really strange problem)?
What happens when you boot a printer without network connectivity (or with the dLink) to 100% and connect it after that to the c2960 switch?
11-10-2012 07:18 PM
Duplicate Post #1.
11-10-2012 11:38 PM
Ferdinand,
11-11-2012 02:12 AM
I already done that, it just stop responding and then re-start by itself.
I also try another switch connect it , it works fine. But when I uplink the switch to cisco it again re-start by itself.
11-14-2013 11:09 AM
Upgrade the software on the Xerox. Had same issue and went down similar line of troubleshooting.
System software version of 0161.132.221.29100
resolved issue when we went to version ending in 223.02693
