Problem Creating Extended VLANs
Here is my question:
Can we create extended VLANs on Switches running VTP version 2 in transparent mode?
Mark Yeates
Level 7
Level 7
AFAIK extended vlans are only supported on VTP version 3.
Mark
As far I know VTP version 3 is only available in 6500 series switches running CATOS not CAT IOS.
Are you still sure with your answer?
You are correct about 6500's running CATos supporting VTP version 3. Yes you can use extended vlans as long as you are in transparent mode in VTP version 2. Sorry for the misunderstanding on the original post.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swvlan.html#wpxref78259
Mark
