Problem GLC-T with Catalyst 2960
Hi Team
We happen case GLC-T with Catalyst 2960 Hang , It can't work
We was reload switch but same ( GLC-T with Catalyst 2960 Hang)
and use command bellow
Switch97#
Switch97#
Switch97#sh int gi 1/0/26 transceiver 5 transceiver de
Switch97#sh int gi 1/0/25 transceiver detail
hulc_sfp_iic_intf_read_eeprom sfp _index 0 yeti_iic_read_retry fail
hulc_sfp_iic_intf_read_eeprom sfp _index 0 yeti_iic_read_retry failDiagnostic Monitoring is not implemented.
Switch97#
Switch97#
Switch97#sh int gi 1/0/25 transceiver detail 6 transceiver        de
Switch97#sh int gi 1/0/26 transceiver detail
hulc_sfp_iic_intf_read_eeprom sfp _index 1 yeti_iic_read_retry fail
hulc_sfp_iic_intf_read_eeprom sfp _index 1 yeti_iic_read_retry failDiagnostic Monitoring is not implemented.
We try IOS Software EX3, EX4, EX5 and 15-2.2 but can't problem
Please suggest case to me
5 Replies 5
InayathUlla Sharieff
Catalyst 2960S-48FPS-L
Catalyst 2960S-48LPS-L
Catalyst 2960S-24PS-L
Catalyst 2960S-48TS-L
Catalyst 2960S-24TS-L
Catalyst 2960S-48TS-S
Catalyst 2960S-24TS-S
Catalyst 2960S-F48FPS-L
Catalyst 2960S-F48LPS-L
Catalyst 2960S-F24PS-L
Catalyst 2960S-F48TS-L
Catalyst 2960S-F24TS-L
Catalyst 2960S-F48TS-S
Catalyst 2960S-F24TS-S
GLC-T=
cisco WS-C2960X-24TS-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FCW1832A38M
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : F0:9E:63:F7:8B:00
Motherboard assembly number     : 73-15973-02
Power supply part number        : 341-0529-02
Motherboard serial number       : FOC183234M6
Power supply serial number      : LIT18220612
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C2960X-24TS-L
Daughterboard assembly number   : 73-14200-03
Daughterboard serial number     : FOC18319MMY
System serial number            : FCW1832A38M
Top Assembly Part Number        : 800-41470-01
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : CMMMU00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x12
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960X-24TS-L   15.0(2)EX3            C2960X-UNIVERSALK9-M
We have similar issue going on the below thread:
https://supportforums.cisco.com/discussion/11944481/glc-lx-2960-x-sfp-slot-wont-link-4503-sfp
Check if that helps
The Switch and IOS which you are running should support GLC-T SFp.
Thank you insharie
We try IOS Software EX3, EX4, EX5 and 15-2.2 but can't problem GLC-T hang
Which Port  is GLC-T down , we try reload but don't can must unplug cable (220volt)
