Problem ip SLA not update Gateway of last resort
admintitrsb
In 3750 Switch i have IP SLA configuation
ip local policy route-map ICMP_SLA
ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 10
ip route 0.0.0.0 0.0.0.0 192.168.0.250 200
But my Gateway of last resort is not updated by IP SLA and the default route stay to the secondary link
Pirmary GTW : 192.168.1.1
Secondary GTW : 192.168.0.250
#sh ip route track-table
 ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 10 state is [up]
#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.0.250 to network 0.0.0.0
S*    0.0.0.0/0 [200/0] via 192.168.0.250
      10.0.0.0/8 is variably subnetted, 17 subnets, 3 masks
If i disconect my interface to secondary GTW all internet is Down.
have you ever seen this problem ?
10 Replies 10
Reza Sharifi
192.168.1.1 is not in your routing table. Are you sure it is alive?
Can you ping it?
Can you trace route to an Internet destination sourcing it from 192.168.1.x?
Are both GTWs in the same subnet?
yes the GTW are in the same subnet (192.168.0.0/22) and i can ping it
#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/9 ms
See routing Table :
#sh ip route
C        10.1.0.0/24 is directly connected, Vlan100
L        10.1.0.2/32 is directly connected, Vlan100
**********Other Routes in 10.0.0.0 subnets************
L        10.47.85.128/32 is directly connected, Virtual3
C     192.168.0.0/22 is directly connected, Vlan1
      192.168.1.0/32 is subnetted, 1 subnets
L        192.168.1.7 is directly connected, Vlan1
For Traceroute:
#traceroute 8.8.8.8
Tracing the route to 8.8.8.8
VRF info: (vrf in name/id, vrf out name/id)
  1 72.142.127.41 9 msec 33 msec 8 msec --> is My Wan GTW on my secondary internet link
  2 209.148.252.106 8 msec 8 msec 8 msec
  3 209.148.249.214 25 msec 17 msec 0 msec
  4 209.148.229.225 17 msec 25 msec 8 msec
  5 209.148.235.137 17 msec
    209.148.230.14 25 msec 17 msec
  6 72.14.222.87 16 msec 33 msec 16 msec
  7 108.170.250.225 9 msec 8 msec 34 msec
  8 108.170.227.43 16 msec
    108.170.227.171 8 msec
    108.170.236.11 34 msec
  9 google-public-dns-a.google.com (8.8.8.8) 16 msec 42 msec 16 msec
Can you clarify?
You have an SVI for vlan 1 on the 3750 with IP address of 192.168.1.7?
The peer IPs are 192.168.1.1 and 192.168.0.250
They are all in a /22 subnet?
Yes all ip are in VLAN1
192.168.0.0/22
129.168.1.7 : Is my Core Switch 3750
192.168.1.1 is my FireWall-1 (Primary internet link)
192.168.0.250 is My FireWall-2 (Secondary internet link)
Can you try the same default routes without the tracking configuration and see if the primary shows up in the routing table?
Also, what is the output of "sh ver" from the 3750?
Can you explain me what you are saying by : "without the tracking configuration"
There is the show version :
#sh vers
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 18-Sep-17 06:58 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
**SWITCHNAME** uptime is 16 weeks, 4 days, 14 hours, 11 minutes
System restarted at 06:35:53 UTC Fri Dec 8 2017
System image file is "flash:/c3750e-universalk9-mz.152-4.E5/c3750e-universalk9-mz.152-4.E5.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO152*****
Last reset from power-on
22 Virtual Ethernet interfaces
1 FastEthernet interface
56 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 44:D3:CA:**:**:**
Motherboard assembly number     : 73-12530-05
Motherboard serial number       : FDO152*****
Model revision number           : A0
Motherboard revision number     : B0
Model number                    : WS-C3750X-24T-S
Daughterboard assembly number   : 800-32727-01
Daughterboard serial number     : FDO152*****
System serial number            : FDO152*****
Top Assembly Part Number        : 800-31327-02
Top Assembly Revision Number    : C0
Version ID                      : V02
CLEI Code Number                : COMJV*****
Hardware Board Revision Number  : 0x03
Switch Ports Model                     SW Version            SW Image
     1 30    WS-C3750X-24              15.2(4)E5             C3750E-UNIVERSALK9-M
*    2 30    WS-C3750X-24              15.2(4)E5             C3750E-UNIVERSALK9-M
Switch 01
Switch Uptime                   : 16 weeks, 4 days, 12 hours, 42 minutes
Top assembly part number        : 800-31327-02
Top assembly revision number    : C0
Version ID                      : V02
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Configuration register is 0xF
Please share your configuration so that we could see where the static route is blocked. There could be a policy or an access-list blocking the traffic. Also, share us the output of "sh ip sla statistics".
HTH,
Meheretab
Here is the informations :
#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
        Latest RTT: 23 milliseconds
Latest operation start time: 18:09:26 UTC Thu Apr 5 2018
Latest operation return code: OK
Number of successes: 525
Number of failures: 0
Operation time to live: Forever
IPSLA operation id: 2
        Latest RTT: 9 milliseconds
Number of successes: 523
Number of failures: 1
What I mean is this
no ip local policy route-map ICMP_SLA
So, no sla policy and no track at the end of the first default route.
Also, looking at your switch, you have IP Base license. In order to run SLA, IP Services license needed but let's try above and see if the first default route shows up in the routing table.
just to make sure there is a risk of losing the connection with the switch by disabling IP SLA?
My Switch is remote (several hundred kilometers)
