i have a big problem because i configure a vlans with vrf and HSRP but, when i do "show hsrp brief", dont show this interfaces and, i can ping virtual IP. it seems hsrp dont work.
SWSERVSCAMILO_N7010_A#
interface Vlan405
description smsc-fwatlas1
no shutdown
vrf member smscoym
ip address 10.116.50.129/29
hsrp 205
preempt delay minimum 30
ip 10.116.50.131
SWSERVSCAMILO_N7010_B# sh run inter vlan 405
!Command: show running-config interface Vlan405
!Time: Thu Nov 22 17:35:55 2012
version 6.0(3)
interface Vlan405
description smsc-fwatlas2
no shutdown
vrf member smscoym
ip address 10.116.50.130/29
hsrp 205
priority 95
ip 10.116.50.131
SWSERVSCAMILO_N7010_B# ping 10.116.50.129 vrf smscoym
PING 10.116.50.129 (10.116.50.129): 56 data bytes
64 bytes from 10.116.50.129: icmp_seq=0 ttl=254 time=1.064 ms
64 bytes from 10.116.50.129: icmp_seq=1 ttl=254 time=0.678 ms
64 bytes from 10.116.50.129: icmp_seq=2 ttl=254 time=0.768 ms
64 bytes from 10.116.50.129: icmp_seq=3 ttl=254 time=0.711 ms
64 bytes from 10.116.50.129: icmp_seq=4 ttl=254 time=0.883 ms
--- 10.116.50.129 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.678/0.82/1.064 ms
SWSERVSCAMILO_N7010_B# ping 10.116.50.130 vrf smscoym
PING 10.116.50.130 (10.116.50.130): 56 data bytes
64 bytes from 10.116.50.130: icmp_seq=0 ttl=255 time=0.606 ms
64 bytes from 10.116.50.130: icmp_seq=1 ttl=255 time=0.525 ms
64 bytes from 10.116.50.130: icmp_seq=2 ttl=255 time=0.455 ms
64 bytes from 10.116.50.130: icmp_seq=3 ttl=255 time=0.484 ms
64 bytes from 10.116.50.130: icmp_seq=4 ttl=255 time=0.561 ms
--- 10.116.50.130 ping statistics ---
round-trip min/avg/max = 0.455/0.526/0.606 ms
SWSERVSCAMILO_N7010_B# ping 10.116.50.131 vrf smscoym
PING 10.116.50.131 (10.116.50.131): 56 data bytes
Request 0 timed out
^C
--- 10.116.50.131 ping statistics ---
2 packets transmitted, 0 packets received, 100.00% packet loss
SWSERVSCAMILO_N7010_A# sh run vrf smscoym
!Command: show running-config vrf smscoym
!Time: Thu Nov 22 17:55:29 2012
version 6.0(3)
vrf context smscoym
router ospf smscoym
vrf smscoym
interface Vlan405
vrf member smscoym
interface Ethernet2/5
vrf member smscoym
ip address 10.116.50.145/30
ip router ospf smsc area 0.0.0.2
SWSERVSCAMILO_N7010_A# sh run interface vlan 405
!Time: Thu Nov 22 17:55:37 2012
version 6.0(3)
interface Vlan405
no shutdown
vrf member smscoym
hsrp 205
ip 10.116.50.131
SWSERVSCAMILO_N7010_B# sh run vrf smscoym
!Time: Thu Nov 22 17:56:23 2012
version 6.0(3)
vrf context smscoym
router ospf smscoym
vrf smscoym
interface Vlan405
vrf member smscoym
!Time: Thu Nov 22 17:56:26 2012
version 6.0(3)
interface Vlan405
no shutdown
vrf member smscoym
hsrp 205
priority 95
ip 10.116.50.131
i can not ping the virtual ip.
WSERVSCAMILO_N7010_A# Show ip interface brief
IP Interface Status for VRF "default"(1)
Interface IP Address Interface Status
Vlan100 10.116.240.245 protocol-up/link-up/admin-up
Vlan201 172.17.196.2 protocol-up/link-up/admin-up
Vlan801 10.116.43.244 protocol-up/link-up/admin-up
Vlan803 10.116.49.2 protocol-up/link-up/admin-up
Vlan804 10.116.49.125 protocol-up/link-up/admin-up
Vlan805 10.116.49.189 protocol-up/link-up/admin-up
Vlan806 172.25.26.66 protocol-up/link-up/admin-up
Vlan807 172.25.26.194 protocol-up/link-up/admin-up
Vlan808 172.25.23.124 protocol-up/link-up/admin-up
Vlan809 172.25.23.92 protocol-up/link-up/admin-up
Vlan838 172.17.66.130 protocol-up/link-up/admin-up
Vlan851 172.25.25.45 protocol-up/link-up/admin-up
Eth2/1 10.116.240.253 protocol-up/link-up/admin-up
SWSERVSCAMILO_N7010_A# show hsrp
Vlan201 - Group 201 (HSRP-V1) (IPv4)
Local state is Active, priority 120 (Cfged 120), may preempt
Forwarding threshold(for vPC), lower: 1 upper: 120
Preemption Delay (Seconds) Minimum:30
Hellotime 3 sec, holdtime 10 sec
Next hello sent in 1.976000 sec(s)
Virtual IP address is 172.17.196.1 (Cfged)
Active router is local
Standby router is 172.17.196.3 , priority 95 expires in 8.445000 sec(s)
Authentication text "cisco"
Virtual mac address is 0000.0c07.acc9 (Default MAC)
28 state changes, last state change 1w6d
IP redundancy name is hsrp-Vlan201-201 (default)
Vlan803 - Group 202 (HSRP-V1) (IPv4)
Local state is Active, priority 100 (Cfged 100), may preempt
Forwarding threshold(for vPC), lower: 1 upper: 100
Virtual IP address is 10.116.49.1 (Cfged)
Standby router is 10.116.49.3 , priority 95 expires in 1.265000 sec(s)
Virtual mac address is 0000.0c07.acca (Default MAC)
11 state changes, last state change 1w6d
IP redundancy name is hsrp-Vlan803-202 (default)
Vlan804 - Group 203 (HSRP-V1) (IPv4)
Virtual IP address is 10.116.49.126 (Cfged)
Standby router is 10.116.49.124 , priority 95 expires in 3.396000 sec(s)
Virtual mac address is 0000.0c07.accb (Default MAC)
IP redundancy name is hsrp-Vlan804-203 (default)
Vlan805 - Group 204 (HSRP-V1) (IPv4)
Virtual IP address is 10.116.49.190 (Cfged)
Standby router is 10.116.49.188 , priority 95 expires in 4.345000 sec(s)
Virtual mac address is 0000.0c07.accc (Default MAC)
IP redundancy name is hsrp-Vlan805-204 (default)
Vlan806 - Group 206 (HSRP-V1) (IPv4)
Virtual IP address is 172.25.26.65 (Cfged)
Standby router is 172.25.26.67 , priority 95 expires in 1.105000 sec(s)
Virtual mac address is 0000.0c07.acce (Default MAC)
IP redundancy name is hsrp-Vlan806-206 (default)
Vlan807 - Group 207 (HSRP-V1) (IPv4)
Next hello sent in 1.975000 sec(s)
Virtual IP address is 172.25.26.193 (Cfged)
Standby router is 172.25.26.195 , priority 95 expires in 8.975000 sec(s)
Virtual mac address is 0000.0c07.accf (Default MAC)
IP redundancy name is hsrp-Vlan807-207 (default)
Vlan808 - Group 208 (HSRP-V1) (IPv4)
Virtual IP address is 172.25.23.126 (Cfged)
Standby router is 172.25.23.125 , priority 95 expires in 3.396000 sec(s)
Virtual mac address is 0000.0c07.acd0 (Default MAC)
IP redundancy name is hsrp-Vlan808-208 (default)
Vlan809 - Group 209 (HSRP-V1) (IPv4)
Virtual IP address is 172.25.23.94 (Cfged)
Standby router is 172.25.23.93 , priority 95 expires in 6.497000 sec(s)
Virtual mac address is 0000.0c07.acd1 (Default MAC)
IP redundancy name is hsrp-Vlan809-209 (default)
Vlan838 - Group 211 (HSRP-V1) (IPv4)
Virtual IP address is 172.17.66.129 (Cfged)
Standby router is 172.17.66.131 , priority 95 expires in 5.145000 sec(s)
Virtual mac address is 0000.0c07.acd3 (Default MAC)
2 state changes, last state change 1d21h
IP redundancy name is hsrp-Vlan838-211 (default)
Vlan851 - Group 210 (HSRP-V1) (IPv4)
Virtual IP address is 172.25.25.44 (Cfged)
Standby router is 172.25.25.46 , priority 95 expires in 3.396000 sec(s)
Virtual mac address is 0000.0c07.acd2 (Default MAC)
17 state changes, last state change 1w6d
IP redundancy name is hsrp-Vlan851-210 (default)
