Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi,I am trying to set up an SSH connection to my switch, but right now there is some lower level problem. I have set up my FastEthernet0 interface to ip address dhcp and the command show interfaces FastEthernet0 shows the correct address. Even if I t...
limex by Level 1
  • 0 Views
  • 0 replies
Resolved! Catalyst 9500-16X
Hello everyone,I am a student, and for a paper i am doing i was wondering if Catalyst 9500-16X was able to do VPN IPSEC as a client, connecting to a cloud VPN IPSEC server. The use case is a Collapse Core topology and i would use 2 C9500-16X as the c...
Hello,Studying for my CCNA and I thought I'd practice some basic configurations, such as router on a stick. I setup 4 PC's (each representing an imaginary number of hosts) each with a vlan attached to a switch leading to a router, with the link betwe...
We're seeing a continuous string of the following messages on a 9407 running 17.9.5.  Eventually the switch crashes.  I can't find any info on what these messages mean exactly and whether we're looking at a software or hardware fault.  The supervisor...
hello every body what is the differentsfp-10/25g-lr-s (10-3251-01) and sfp-10/25g-lr-s (10-3251-02)
nagy by Level 1
  • 106 Views
  • 2 replies
At Cisco Live I was able to get into a lab where the advisor showed a feature that I cannot find any information on how to implement or use. It was quick example. On the switch you can enable a packet trace and actually watch the packet traverse from...
