problem with ISDN Connection
abdulwalicisco7
Hello
I have problem with ISDN Connection, I use ISDN configuration in cisco Router using Dial in demand command , the problem is the ISDN link doesn’t automatic activate to UP status  when the client and host connected to router want to use network , and to activate the link I need to  access to the router and make ping to next router and then the ISDN Link becomes active
Please tell me how can I fix this problem
Thanks for all
paolo bevilacqua
Likely is not configured correctly, you can study and troubleshoot yourself, or hire a professional for sure results.
spremkumar
Level 9
Level 9
Hi Abdul
Can you post your config here?
regs
Dear spremkumar
Thank in advance
please find  attachment   first file is  for  Main office   and  the  second is for branche
regs
