Problem with LACP between SX550X and C3750
Inaki Kortazar
Hi!
I´m trying to connect two Cisco stack through 1 LACP of 4 Ten Gigabit Ethernet fiber ports (2 ports on each device)
One stack is made of 3 C3750X-48 devices and the other one is made of 2 SX550Z-16FT.
I tried to connect them through a port channel but I am having problems with the SX550Z side.
Are CLI commands different in this type of switches? it does not recognice commands like show ip int brief.
(config)#interface range TenGigabitEthernet2/0/9-10
(config-if-range)#channel-group 11 mode auto
sw-be-CPD1(config)#interface port-channel 11
sw-be-CPD1(config-if)#switchport mode trunk
sw-be-CPD1(config-if)#exit
I get this information when show run (show etherchannel summary does not work in this device..)
interface TenGigabitEthernet2/0/9
channel-group 11 mode on
interface TenGigabitEthernet2/0/10
interface Port-Channel11
spanning-tree link-type point-to-point
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
#show interfaces status
Ch Type Duplex Speed Neg control State
Po11 10G Full 10000 Enabled Off Up          -----SPEED SHOULD BE 20000, DOESNT IT?
Thank you and Regards
6 Replies 6
balaji.bandi
if you want to EtherChannel to be LACP make below change.
channel-group 11 mode active
show EtherChannel 11 summary will give you how many port up and participated in Port-channel.
BB
Hello BB
Thank you for your help
channel-group 11 mode has justo two modes on and auto..
Sorry maybe some limitation - then I go with control
channel-group 11 mode on both the side.
also, post-show EtherChannel 11 summary to look
BB
Hello
Both sides has channel group 11 mode on on their ports ,but the message is new for me..
sw-be-034(config-if-range)#channel-group 11 mode on
18-Jun-2019 05:41:54 %2SWTRUNK-I-TRNKPORTPARAM: auto-negotiation/adv. capabilities of port te2/0/9 differ from auto-negotiation/adv. capabilities of Po11
18-Jun-2019 05:41:54 %TRUNK-I-PORTADDED: Port te2/0/9 added to Po11
18-Jun-2019 05:41:54 %STP-W-PORTSTATUS: te2/0/10: STP status Forwarding
18-Jun-2019 05:41:54 %LINK-I-Up: Po11
18-Jun-2019 05:41:54 %2SWTRUNK-I-TRNKPORTPARAM: auto-negotiation/adv. capabilities of port te2/0/10 differ from auto-negotiation/adv. capabilities of Po11
18-Jun-2019 05:41:54 %TRUNK-I-PORTADDED: Port te2/0/10 added to Po11
sw-be-034(config-if-range)#18-Jun-2019 05:41:55 %STP-W-PORTSTATUS: Po11: STP status Forwarding
show Etherchannel 11 summary command does not work in these devices  (at least,not in console connection)
I can see something similar in the following command:
sw-be-035#show interfaces port-channel
Load balancing: src-dst-mac.
Gathering information...
Channel Ports
Po11 Active: te1/0/9-10
sw-be-035#show interfaces status
Port Type Duplex Speed Neg ctrl State Pressure Mode
te1/0/9 10G-Fiber Full 10000 Disabled Off Up Disabled Off
te1/0/10 10G-Fiber Full 10000 Disabled Off Up Disabled Off
Po11 10G Full 10000 Enabled Off Up   -----  should it be 20000 I guess
As you are looking at is Speed 10000.  It is showing correctly. If you will look at the bandwidth then it will show you the double or multiply with your interfaces and interface speed.
sho interfaces port-channel 5
Port-channel5 is up, line protocol is up (connected)
Hardware is EtherChannel, address is xxx.xxx.xxx (bia xxx.xxx.xxx)
Description: ToCore
MTU 1500 bytes, BW 20000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is
Example copied from the 10G links but the method will be the same.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Sorry, I was more referring to the command on Cat 3750 model, you are right, the command is different in SMB switches.
here is a guide :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-550x-series-stackable-managed-switches/smb5848-configuring-lag-settings-on-a-switch-through-cli.html#LAGConfigurationProcedure
can you post-show interface port-channel 11 - should give you output what you looking for
BB
