Problem with NAT configuration
shoaib sheikh
Level 3
Level 3
Hello All,
I have done NAT config on the switch but it is not working. If anyone could be of help.
interface Vlan25
 ip address 10.18.95.126 255.255.255.224
 ip nat outside
end
interface Vlan2
 ip address 192.168.1.1 255.255.255.248
 ip nat inside
show run | sec access-list 101
access-list 101 permit ip 192.168.1.0 0.0.0.7 any
access-list 101 permit icmp 192.168.1.0 0.0.0.7 any
ip nat inside source list 101 interface Vlan25 overload
ping 10.18.96.55 source vlan 25
Sending 5, 100-byte ICMP Echos to 10.18.96.55, timeout is 2 seconds:
Packet sent with a source address of 10.18.95.126
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Packet sent with a source address of 192.168.1.1
Success rate is 0 percent (0/5)
The reason I have to do nat is because I do not have reverse route for 192 network.
11 Replies 11
dasiimwe
Level 2
Level 2
enable 'ip routing' on the switch. can you share 'show ip route'?
routing is already enabled.
What is the model of the switch ?
Jon
The only switch which support NAT is 6500. If you use 3750 or something like that, then you may be better off looking to a low end router to do the NAT.
Hello Sergey,
This is 6506 E in VSS.
The thing is, NAT works between interfaces, so did you try to send ping from any host connected to network 192.168.1.0? (not from switch)
Hi Sergey,
I already did it during initial troubleshooting. I initiated ping from host in vlan 2 but that was also not working.
Can you ping from a client and then see what "sh ip nat translations" is showing.
Jon
Hello Jon,
Ricardo Ochoa
Community Member
Can you share the next commands, i supuse in the first ping it wasnt applying NAT at all...
Show ip route
show ip nat translations
Hello
can you confirm  if your subnet addressing is correct for vlan 25 on either side of my your wan connection
Vlan  25 is in an different network then the prefix you are pinging
 Can you post output of routing table as suggested by others
res
paul
Kind Regards
Paul
