problem with PIM
yoram12345
hi all,
I have 2 switch routers 3750 in my Lab which i try to configure PIM.
The configuration is pc with multicast streamer connected to R1 to Router 2 to pc with vlc player.
I configured the ports between the routers as
no switch port
ip adress ...
ip pim sparse-dense
If i pass the pc receiver to R1 so i can get the multicast movie ,but when we move it to r2
not.
also we can see that igmp is received in R2 but not in R1 ,
what am i missing pls ?
Yoram
Reza Sharifi
Yoram,
Without seeing your config, it is hard to tell what is wrong, but have you configured
ip igmp snooping globally and also on each interface/VLAN that connects to each PC?
ip multicast-routing distributed on both routers have been enabled?
Have you configured PIM on both routers, if yes can you see the PIM neighbor by issuing the command "sh ip pim nei" from one of the routers?
Reza
