problem with stack power led yellow?
aurorasanz
Community Member
Hello everybody,
Customer has 2 switches 3750X in stack and everything seems to be all right because the "show power stack" is right:
ESPZAR01SW24#Show env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
TEMPERATURE is OK
Temperature Value: 33 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     LIT14401AWR  OK              Good     Good     350/0
1B  C3KX-PWR-350WAC     LIT144106U5  OK              Good     Good     350/0
2A  C3KX-PWR-350WAC     LIT14401AX1  OK              Good     Good     350/0
2B  C3KX-PWR-350WAC     LIT144106U9  OK              Good     Good     350/0
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
2   Not Present     <>
Aanyway he finds there is a yellow led only for the master switch for power.
Do you know if this may mean something is wrong with the power?
The error found is:
Sep 16 13:59:58.744 CEST: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 1's power stack lost redundancy and is now operating in power sharing mode
The stack is in redundant mode, since this is the output of the command:
ESPZAR01SW24#sh stack-power
Power stack name: Powerstack-2
    Stack mode: Redundant
    Switch 1:
        Power budget: 206
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: 588d.09d0.3680
       Neighbor on port 2: 588d.09d0.3680
    Switch 2:
        Power budget: 206
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Neighbor on port 1: 588d.09d0.5400
        Neighbor on port 2: 588d.09d0.5400
Do you know if the led in yellow means something to consider or just a false alarm?
Thank you very much.
devils_advocate
Level 11
Level 11
From the Cisco website:
A power stack can run in one of two modes, configured by using the command-line interface:
In  power-sharing mode (the default), all input power is available to be  used for power loads. The total available power in all switches in the  power stack (up to four) is treated as a single large power supply, with  power available to all switches and to all powered devices connected to  PoE ports. In this mode, the total available power is used for power  budgeting decisions and no power is reserved to accommodate power-supply  failures. If a power supply fails, powered devices and switches could  be shut down (load shedding).
In  redundant mode, the power from the largest power supply in the system  is subtracted from the power budget, which reduces the total available  power, but provides backup power in case of a power-supply failure.  Although there is less available power in the pool for switches and  powered devices to draw from, the possibility of having to shut down  switches or powered devices in case of a power failure or extreme power  load is reduced.
Do you know how they are configured for power?
May be worth checking and reseating the power ring cables.
