problem with static route
Tshi M
Level 5
Level 5
I have two switches with multiple VLANs interconnected via etherchannel running static routes and EIGRP.
I have a static route on one of the swith that works for some VLANs but not for others. Some traceroute seems to produce a loop.
What could be the problem. When I do a show ip route, the route is being advertised by EIGRP since we redistribute static route?
Tshi M
Level 5
Level 5
Please see attached file.
Etienne
Please post a "sh ip route" from both devices.
Jon
Because of the number of routes, I only posted the route pertinent to the problem.
NY45B3SC00>sh ip route x.225.214.0
Routing entry for x.225.214.0/24
Known via "static", distance 1, metric 0
Redistributing via eigrp 65204
Advertised by eigrp 65204
Routing Descriptor Blocks:
* 192.168.3.14
Route metric is 0, traffic share count is 1
NY45B3SC01>sh ip route x.225.214.0
Known via "eigrp 65204", distance 170, metric 256512, type external
Last update from 10.33.73.2 on Vlan109, 3w6d ago
* 10.33.79.2, from 10.33.79.2, 3w6d ago, via Vlan115
Route metric is 256512, traffic share count is 1
Total delay is 20 microseconds, minimum bandwidth is 10000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
10.33.76.2, from 10.33.76.2, 3w6d ago, via Vlan114
10.33.73.2, from 10.33.73.2, 3w6d ago, via Vlan109
10.33.32.2, from 10.33.32.2, 3w6d ago, via Vlan32
D EX x.225.214.0/24 [170/256512] via 10.33.79.2, 3w6d, Vlan115
[170/256512] via 10.33.76.2, 3w6d, Vlan114
[170/256512] via 10.33.73.2, 3w6d, Vlan109
[170/256512] via 10.33.32.2, 3w6d, Vlan32
S x.225.214.0/24 [1/0] via 192.168.3.14
192.168.0.0/28 is subnetted, 4 subnets
