02-21-2011 11:12 AM - edited 03-06-2019 03:40 PM
I have a problem with the vss in the cisco 6500, the problem was that the one of the two 6500 stayed in mode recovery and we reboot the switch, but still the same. So how can I fix the problem?
the configuration of the vss is the following:
interface TenGigabitEthernet2/5/4
no switchport
no ip address
mls qos trust cos
channel-group 20 mode on
interface TenGigabitEthernet2/5/5
no switchport
no ip address
mls qos trust cos
interface Port-channel20
no switchport
no ip address
switch virtual link 2
mls qos trust cos
no mls qos channel-consistency
interface GigabitEthernet2/3/44
description FastHello-Link1SW2
no switchport
no ip address
dual-active fast-hello
interface GigabitEthernet2/3/45
description FastHello-Link2SW2
no switchport
no ip address
interface GigabitEthernet2/3/46
description IP-BFD-LinkSW2
no switchport
ip address 2.2.2.2 255.255.255.0
bfd interval 100 min_rx 100 multiplier 50
the other switch show me the follow error:
Feb 20 22:23:29: %VSLP-SW2_SPSTBY-3-VSLP_LMP_FAIL_REASON: Te2/5/4: Link down
Feb 20 22:23:29: %VSL-SW2_SPSTBY-5-VSL_CNTRL_LINK: New VSL Control Link Te2/5/5
Feb 20 22:23:29: %VSLP-SW2_SPSTBY-3-VSLP_LMP_FAIL_REASON: Te2/5/5: Link down
Feb 20 22:23:29: %VSLP-SW2_SPSTBY-2-VSL_DOWN: Last VSL interface Te2/5/5 went down
Feb 20 22:23:29: %SATVS_IBC-SW2_SPSTBY-5-VSL_DOWN_SCP_DROP: VSL inactive - dropping cached SCP packet: (SA/DA:0x4/0x4, SSAP/DSAP:0x2/0x1, OP/SEQ:0x1E/0x29, SIG/INFO:0x1/0x502, eSA:0000.0500.0000)
--More-- Feb 20 22:23:29: %VSLP-SW2_SPSTBY-2-VSL_DOWN: All VSL links went down while switch is in Standby role
Feb 20 22:23:36: %PM-SW2_SP-4-PORT_BOUNCED: Port Gi2/3/44 was bounced by Consistency Check IDBS Up.
Feb 20 22:23:36: %PM-SW2_SP-4-PORT_BOUNCED: Port Gi2/3/45 was bounced by Consistency Check IDBS Up.
Feb 20 22:23:36: %PM-SW2_SP-4-PORT_BOUNCED: Port Gi2/3/46 was bounced by Consistency Check IDBS Up
Best Regard
Paolo Kobashikawa
Solved! Go to Solution.
02-21-2011 07:17 PM
Log into the switch (you may use console access) do "wr mem" and reload. Please let us know if it resolves the issue.
02-21-2011 01:21 PM
Hi Paolo,
What is the output of "sh sw vir ro"?
Recovery usually means the the primary switch has failed and it is in recovery mode until it is rebooted. When this happens the backup switch should be primary now.
Reza
02-21-2011 04:24 PM
we had a problem because the primary switch switchover to the recovery mode, so I want to know how to fix the problem, in the log, you can see that the vsl fail down, sometime is for the cable but how can I check the primary switch , because right now is in recovery mode, so I can not enter to the device.
And also how can I check it, if the problem is the hardware of the cisco 6500?
02-21-2011 07:17 PM
02-22-2011 03:20 PM
Dear Sajid, Today I will apply the command "wr mem" and reload, but with that command what will supposed to happend? will the 6500 turn to normal mode? I have another quiestion, right now the the 6500 device is turn off, so just one 6500 is on, if I turn on the " failed device" what would happend with the another device, I mean, could the operating device get down?
02-22-2011 03:34 PM
You will do it on the switch in recovery mode. So, you need to bring it up anyway and then reload. I think, you can use "redundancy reload shelf #" cmd. Recovery mode chassis should not cause any affect to current active one. Current active is affected if VSL link is broken due to any reason.
02-22-2011 03:37 PM
Login to the recovery mode switch, do enable, provide password and then wr mem and then use reload shelf cmd.
02-22-2011 04:28 PM
Dear Said, a question, if I enter by console to the recovery switch, I will enter to that switch or to the active switch? because in another device for example the 3750, When you enter to the device, always is the active switch.
02-22-2011 05:05 PM
You will enter into recovery switch, use console connection
02-22-2011 09:26 PM
how can I write the command "wr mem" and then reload if the recovery device is en rommon?
02-22-2011 09:56 PM
Please recover your switch from rommon condition first. Cisco's website has procedure to recover.
Make sure it has same ios as other switch if your ios is corrupted.
