Problems DHCP
TS40
My ap can connect to the laptop but it doesn't get ip from dhcp but I don't see why. Can someone take a look at this. Must be coming from Router first floor on the left side. Adding the configurations done would be a very big help.
Thanks in advance
Ok @TS40
thanks for that clarifcation.
On Switch 'MLS First Floor' delete this command
and add this one: switchport mode trunk. You should have this now:
Laptop should have an IP address by DHCP now:
Best regards
6 Replies 6
M02@rt37
Hello @TS40
Power on first that router !
Best regards
But it's about this router where the dhcp should come from
Ok @TS40
which laptop don't have IP ADD by DHCP ?
Best regards
So the PC in the screenshot connects to the ap with the WLAN "employees" and the password is Hogent*123 and I should get an ip from dhcp from the router I showed you in the screenshot. But it doesn't work and i do not understand why
Ok @TS40
Best regards
Now on the other side with other ip's I made thisflde configuration approximately. But now my AP does not want to take the right WLANs it takes the WLANs from the right side. I really don't understand how. The new packet tracer is in the attachment. Password is still Hogent*123. And the ip to get on the WLC is 172.68.5.1.
