Problems with Etherchannel
spalislam
Level 3
Level 3
I can't get the Etherchannel to work on my 3550 <--> 2950.
Everything is configured properly, but still etherchannel sometimes brings both of the interfaces up and sometimes shuts one of them down, for no reason. Cables are same, configs same, everything exactly same. I already looked up the error message talking something about balun cable. I am not sure what kind of cable is balun, but I used normal CAT5 crossover cables between switches. Please if anyone has any suggestions, I would really appreciated.
2950 is configured through PO1 (on fa0/23, fa0/24) to PO8 on 3550 (on fa0/44, fa0/43)
Here is the configs:
3550:
! Created by Senad P. on May 2003
! Last configuration change at 10:19:08 MST Thu May 15 2003
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname D2-2001
clock timezone MST -7
vlan 233
vlan 234
vtp domain wb
vtp mode transparent
interface Port-channel1
switchport mode trunk
no ip address
interface Port-channel8
no ip address
... SHORTENED BECAUSE OF CHARRACTER LIMITATION
interface Port-channel9
no ip address
interface Port-channel10
no ip address
interface FastEthernet0/1
switchport access vlan dynamic
no ip address
no logging event link-status
speed 100
duplex full
no snmp trap link-status
storm-control broadcast level 70.00
storm-control multicast level 70.00
storm-control unicast level 85.00
spanning-tree portfast trunk
interface FastEthernet0/2
no ip address
speed 100
duplex full
SHORTENED BECASUE OF CHARACTER LIMITATION
interface FastEthernet0/44
no ip address
speed 100
duplex full
channel-group 8 mode on
interface FastEthernet0/45
no ip address
speed 100
duplex full
channel-group 9 mode on
interface FastEthernet0/46
no ip address
speed 100
duplex full
interface FastEthernet0/47
no ip address
speed 100
duplex full
channel-group 10 mode on
interface FastEthernet0/48
no ip address
speed 100
duplex full
interface GigabitEthernet0/1
description "UPLINK TO CAT6509"
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan234
ip address 137.190.x.x 255.255.x.x
no ip route-cache
ip default-gateway 137.190.x.x
ip classless
no ip http server
2950:
sh run
Building configuration...
vlan 234
vlan 243
vtp domain wb
vtp version 2
vmps server 137.190.
no ip address
speed 100
duplex full
storm-control action trap
no ip address
speed 100
duplex full
SHORTENED BECAUSE OF CHARACTER LIMITATION
interface FastEthernet0/23
description "UPLINK TO 3550"
no ip address
speed 100
duplex full
channel-group 1 mode on
interface FastEthernet0/24
no ip address
speed 100
duplex full
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan234
ip address 137.190. 255.255.
no ip route-cache
D2-2003#
#%ETHCNTR-3-LOOP_BACK_DETECTED
Here is the DEBUG LOG from 2950:
May 21 20:27:57: FEC: pagp_switch_find_master: group 1
May 21 20:27:57: FEC: fec_bundle: Fa0/24
May 21 20:27:57: FEC: add port (Fa0/24) to agport (Po1)
May 21 20:27:57: FEC: fec_set_agport_macaddr: Po1 Fa0/24 (add)
May 21 20:27:57: FEC: pagp_switch_add_port_to_agport: msg to PM to bundle port Fa0/24 with Po1
May 21 20:27:57: FEC: pagp_switch_want_to_bundle: Bndl msg to PM for port Fa0/24 to Agport Po1
May 21 20:27:57: FEC: pagp_switch_hotstandby: for agport Po1
May 21 20:27:57: FEC: pagp_switch_hotstandby: PAgP not enabled on agport Po1
May 21 20:27:57: FEC: pagp_switch_reset_load_index: reading load-index for port Po1
May 21 20:27:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/24, changed state to up
May 21 20:27:59: %LINK-3-UPDOWN: Interface FastEthernet0/23, changed state to up
May 21 20:27:59: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
May 21 20:28:00: FEC: pagp_switch_port_up: Fa0/23
May 21 20:28:00: FEC: pagp_switch_invoke_port_up: Fa0/23
May 21 20:28:00: FEC: pagp_switch_agc_compatable: comparing GC values of Fa0/23 Fa0/24 flag = 1 1
--More-- May 21 20:28:00: FEC: pagp_switch_port_attrib_diff: Fa0/23 Fa0/24 same
May 21 20:28:00: FEC: pagp_switch_agc_compatable: GC values are compatable
May 21 20:28:00: FEC: fec_bundle: Fa0/23
May 21 20:28:00: FEC: add port (Fa0/23) to agport (Po1)
May 21 20:28:00: FEC: fec_set_agport_macaddr: Po1 Fa0/23 (add)
May 21 20:28:00: FEC: pagp_switch_add_port_to_agport: msg to PM to bundle port Fa0/23 with Po1
May 21 20:28:00: FEC: pagp_switch_want_to_bundle: Bndl msg to PM for port Fa0/23 to Agport Po1
May 21 20:28:00: FEC: pagp_switch_hotstandby: for agport Po1
May 21 20:28:00: FEC: pagp_switch_hotstandby: PAgP not enabled on agport Po1
May 21 20:28:00: FEC: pagp_switch_reset_load_index: reading load-index for port Po1
May 21 20:28:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
May 21 20:28:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to up
May 21 20:28:55: %ETHCNTR-3-LOOP_BACK_DETECTED: Loop-back detected on FastEthernet0/24. The port is forced to linkdown.
May 21 20:28:55: FEC: pagp_switch_hotstandby: for agport Po1
May 21 20:28:55: FEC: pagp_switch_hotstandby: PAgP not enabled on agport Po1
May 21 20:28:55: FEC: pagp_switch_port_down: Fa0/24
May 21 20:28:55: FEC: pagp_switch_invoke_port_down: Fa0/24
--More-- May 21 20:28:55: FEC: fec_unbundle: Fa0/24
May 21 20:28:55: FEC: pagp_switch_delete_port_from_agport: delete_port_from_agport: for port Fa0/24
May 21 20:28:55: FEC: delete port (Fa0/24) from agport (Po1)
May 21 20:28:55: FEC: pagp_switch_remove_from_bundle: Un-Bndl msg NOT send to PM for port Fa0/24 from Po1
May 21 20:28:55: FEC: pagp_switch_reset_load_index: reading load-index for port Po1
May 21 20:28:55: FEC: fec_set_agport_macaddr: Po1 Fa0/24 (remove)
May 21 20:28:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/24, changed state to down
May 21 20:31:21: %LINK-3-UPDOWN: Interface FastEthernet0/24, changed state to up
May 21 20:31:22: FEC: pagp_switch_port_up: Fa0/24
May 21 20:31:22: FEC: pagp_switch_invoke_port_up: Fa0/24
May 21 20:31:22: FEC: pagp_switch_agc_compatable: comparing GC values of Fa0/24 Fa0/23 flag = 1 1
May 21 20:31:22: FEC: pagp_switch_port_attrib_diff: Fa0/24 Fa0/23 same
May 21 20:31:22: FEC: pagp_switch_agc_compatable: GC values are compatable
May 21 20:31:22: FEC: fec_bundle: Fa0/24
May 21 20:31:22: FEC: add port (Fa0/24) to agport (Po1)
May 21 20:31:22: FEC: fec_set_agport_macaddr: Po1 Fa0/24 (add)
May 21 20:31:22: FEC: pagp_switch_add_port_to_agport: msg to PM to bundle port Fa0/24 with Po1
--More-- May 21 20:31:22: FEC: pagp_switch_want_to_bundle: Bndl msg to PM for port Fa0/24 to Agport Po1
May 21 20:31:22: FEC: pagp_switch_hotstandby: for agport Po1
May 21 20:31:22: FEC: pagp_switch_hotstandby: PAgP not enabled on agport Po1
May 21 20:31:22: FEC: pagp_switch_reset_load_index: reading load-index for port Po1
May 21 20:31:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/24, changed state to up
D2-3003#
lgijssel
Level 11
Level 11
When looking at your configs I get the idea that the channel numbers are not the same on both devices. This is a requirement while the channel-group nr is communicated between them.
When you attach the 2950 to channel-group 10 on the 3550, you MUST configure channel-group 10 on the 2950, even if there is only one channel.
Leo
Leo,
Thanks for the info. And please forgive me, I am not doubting your knowledge, just wanted to make sure about it. However, are you sure that channel numbers are supposed to be same? If that is the case, 2950 supports only up to 6 channels, and 3550 I think about 24 if I remember correctly. So what happens when I configure more then a 6 channels of 2950s into 3550. Next channel after six-th one would be 7, 8 and so on. However, I cannot configure channel # higher then 6 on 2950. With this, I am limiting 3550 to only 6 channels.
Now, I have not got experience in doing ether-channels. However, I was thinking logicly and thoughed that Cisco would not limit 3550s to 2950 limitation.
Please advise.
hnorvik
Community Member
I hope you fixed your issue since this is 1 1/2 year ago.
The port numbering may be different on the two sides of the etherchannel like you have; Po1 to Po8.
However looking at your log and config, I woudl suggest that you use PAgP on two devices that can talk PAgP. Use channel-group 1 mode desirable instead of mode on.
show etherchannel and show pagp will then help you find the error.
