Problems with initial config of Cisco 861.
jdwalters
I just received a refurbished Cisco 861 wireless router and have been trying to configure it.  I have followed the steps for setting it up, but every time I type a command with dot11, I get the invalid input message.  It appears that there should be a Dot11 interface as well, but there is not.
I would prefer to configure it through the CLI, but frustration has led me to try to access it through the GUI.  I set the FastEthernet 4 IP address so that I could access it, then logged in.  However, I am told that my browser is too old and that java is not enabled -- neither of which is true.  The window says that I am using Netscape 7, which I am not.  So that is a dead-end as well.
Any help or suggestions would be greatly appreciated.  The software info is below:
Cisco IOS Software, C860 Software (C860-UNIVERSALK9-M), Version 12.4(20)T3, RELE
ASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 29-Apr-09 09:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(15r)XZ2, RELEASE SOFTWARE (fc1)
Router uptime is 23 minutes
System returned to ROM by reload
System image file is "flash:c860-universalk9-mz.124-20.T3.bin"
Philip D'Ath
Although a little complicated for your needs, check out this guide.
https://supportforums.cisco.com/document/62176/configuration-example-861w881w891w-series-isrs
