problems with new wlan in controller
chinpohpang851
Level 3
Level 3
we're using WLC 5500 (7.0.98.0) currently running 3 existing WLAN A, B, C are working fine. Now I created a new WLAN follow exactly the config in Interface and WLAN(with correct vlan id and new interface), I can also see the broadcast SSID but I cannot ping the WLC from CoreSW or via versa. Trunk port to CoreSW allowed for all VLANs, currently WLAN are working fine so I'm not sure what's missing.
Leo Laohoo
If you've created a new WLAN, did you also create a new Dynamic Interface?
Yes. Created under Controller>Interfaces. I follow exactly the  current WLAN setup. Maybe I need to open access for dhcp service(in other vlan) in my ACL? But my LAN is working.
chinpohpang851
Level 3
Level 3
I found one of the problem which is my ACL is blocking from ping from controller to CoreSW, now I made some changes and I can ping the WLAN interface now. But I still not getting IP from DHCP server(192.168.50.1) using WLAN, LAN is ok.
This is the ACL i applied on vlan215, for LAN(working fine) and WLAN(not getting IP from dhcp).
Extended IP access list 140
9 permit ip any 192.168.215.0 0.0.0.255 (5 estimate matches)
10 deny ip any 192.168.0.0 0.0.255.255 (276 estimate matches)
20 permit ip any any (31216 matches)
I solved the problem by adding one more line in ACL.
access-list 110 permit udp 192.168.215.0 0.0.0.255 host 192.168.50.1 eq bootps
But why we need to add this for WLAN not LAN?
