Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
Hi there,im configuring a Stack of 4 C9300-48P and now i have the problem that my uplink starts flapping after around 15-20min.im really confused because of this behaviour and im trying to fix it since 3 weeks but it wont work.Im using Flexoptix GBIC...
Hello,I am not able to successfully download running config via scp from cat9300.$ scp  cisco@172.0.0.1:/system/running-config backup.txtPrivilege denied.Connection to 172.0.0.1 closed by remote host.Please note: SSH into the box with same privileges...
Netmart by Level 3
  • 76 Views
  • 2 replies
We are using Catalyst 3650 Switch for our internal testing and we wanted to know which PHY model is used in the Switch design for further analysis
When installing a new software version on a 9300 switch, a typical command is:install add file path:file.bin activate commitHowever, this requires some interaction (eg responding y/n) and it will be incomplete with out it. After which a reload is und...
Hello Cisco Community,I am experiencing a repeating issue with a stack of two Cisco Catalyst C1300-24XTS switches, used in a production network. Approximately once a month, stack of  switches suddenly becomes unresponsive and freezes completely. The ...
tomas22 by Level 1
  • 1096 Views
  • 7 replies
Hello,We observed packet bursts on a couple of interfaces, cat 9300And we do also observe Hardware packet drops at TH2. And I am wondering:What type of traffic is buffered in  Queue 0 - 7.What is the difference between Drop-TH0, Drop-TH1, and Drop-TH...
Netmart by Level 3
  • 485 Views
  • 5 replies
  • 1 Helpful votes
Hello all,      Currently using two 9300L switches (17.12.03) and creating an ERSPAN session.  I was able to get traffic mirrored from my source switch to my destination sw and it is showing up on my wireshark machine, but the tunnel shows up/down.  ...
Hello, On a Cisco 3850 switch, I have an SVI (VLAN 2). When I do show run int vlan 2 Vlan2 is up, line protocol is up , Autostate EnabledHardware is Ethernet SVI, address is 00b6.70c4.e177 (bia 00b6.70c4.e177)Description: Vlan 2 - XXXXXInternet addre...
abtt-39 by Level 1
  • 474 Views
  • 9 replies
Unanswered Topics
