Buenas tardes a todos:
Necesito saber por qué este proceso está pegado en 93% y como se puede bajar y los efectos de hacer lo sugerido. se enviá los issues:
SW#sh proc cpu | exc 0.0
CPU utilization for five seconds: 97%/0%; one minute: 96%; five minutes: 96%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
51 5971720 17889032 333 3.19% 2.99% 2.99% 0 Cat4k Mgmt HiPri
52 206956356 35760512 5787 94.07% 93.21% 93.41% 0 Cat4k Mgmt LoPri
sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version 12.2(53)SG2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 16-Mar-10 00:54 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11B95764
ROM: 12.2(31r)SGA4
Pod Revision 0, Force Revision 31, Gill Revision 19
SW_TRKDMZ_LGVL uptime is 8 weeks, 6 days, 6 hours, 11 minutes
System restarted at 04:20:32 Chile Sat Sep 3 2011
System image file is "bootflash:cat4500-ipbase-mz.122-53.SG2.bin"
cisco WS-C4948-10GE (MPC8540) processor (revision 5) with 262144K bytes of memory.
Processor board ID FOX1502G7BQ
MPC8540 CPU at 667Mhz, Fixed Module
Last reset from PowerUp
2 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Por su ayuda muchas gracias.
Atte. Carlos Chavarriga B. Ingeniero Operaciones.
