Procurve <> CIsco Trunk connectivity
amit bhatnagar
Beginner
Beginner
Hello ,
We have existing network in which CIsco 6513 is core switch and access swicth is Cisco Express 500 , we are replacing the Cisco 500 with HP Procurve switch as new access switch . I have put below configration on both sides . Will be great if any one can share thoughts before I plan for migration .
Note: there is only 1 vlan which is vlan 900 that is required to travel .
6513Core Switch Trunk port Config
interface GigabitEthernet3/34
description *** Connects to HP Procurve ***
switchport
switchport trunk allowed vlan 900
switchport mode trunk
no ip address
speed 100
duplex full
end
HP Procurve Configration
vlan 900
   name "connects to 6513 3/34"
   untagged 1-48
   ip address 10.101.x.x 255.255.255.0
   tagged 49
   exit
interface 49
   speed-duplex 100-full
Thanks for help
Amit
~chris
Beginner
Beginner
my last ProCurve configuration is already something back, but your configuration looks good.
interface 1-48 is untagged (it's like "switchport access vlan 900) and interface 49 will tag packets for vlan 900.
So your configuration should work fine.
