PVLAN Edge (protected port) over FlexStack
indiantrails
           According to Cisco:
The PVLAN edge (protected port) is a feature that has only local significance to the switch (unlike Private Vlans), and there is no isolation provided between two protected ports located on different switches.
Does ports setup as "protected port" on member #1 of  FlexStack stacked switch can comunicate with other ports  set up as "protected port" on member#2  of  FlexStack stacked switch?
Reza Sharifi
That is refereeing to two different switches.  When you stack the switches, they are logically one switch.
Thanks.
