01-14-2013 01:44 AM - edited 03-07-2019 11:04 AM
Our switches use the default PVSTP and due to the rapid convergence time I'm considering RSTP or even PVRSTP. I was wondering you use guys in the field normally use and are happy with, why wouldn't I use RSTP?
Due to all root ports being re-calculated I guess I should change this out of business hours?
01-14-2013 02:08 AM
Hi Andy,
Personally, I see no reason not to use RSTP. In fact, new versions of the 802.1D standard do not specify STP at all, and instead talk about RSTP only.
One thing to be very careful about: it is necessary that all access ports be configured as PortFast ports. In RSTP parlance, this means they are considered edge ports and won't be affected by topology changes in the network, particularly by the Proposal/Agreement process. Without configuring the ports towards end hosts as PortFast, a Proposal/Agreement wave may result in their temporary blocking but because hosts do not send Agreements, these ports would be blocked for 30 seconds before reaching the Forwarding state again. Just turning on the RSTP without making sure that access ports are configured as edge ports may actually worsen the perceived convergence time in your network. Quite a few network administrators learned this the hard way.
Ideally, your switches should be configured using spanning-tree portfast default global configuration command that causes all current and future access ports will be considered as PortFast ports.
Depending on how many VLANs you run, you could actually also benefit from running MSTP. However, MSTP is more complex to understand and initially set up, but rewards you in consuming less resources, and is the standardized way to go in multi-vendor VLAN-aware environments.
You should definitely request a maintenance window for STP upgrade. There will be network outages.
Best regards,
Peter
01-14-2013 02:51 AM
Thanks this is very informative. My root switch is a stack of 2 3750s which I'm replacing with 2 3750Gs soon so I guess I could make it RSTP then and set portfast globally?
I'm reading MSTP at the moment as part of my CCNP and hmm I think I need to get my head round that first
I guess I could also consider RPVST+ too, but I don't think I will benefit from this.
01-14-2013 02:14 AM
Hi Andy,
You can use RSTP for the rapid convergence and it is advisable do the change during off business hours.
Refer:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml
Aru
*** Please rate if the post is useful ***
01-14-2013 02:54 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In my current employer's environment, our team supports about 6,000 Cisco devices, most of which are switches (although half or more are L3 switches). Our current standard actually calls for RSTP and portfast [and bpduguard] on each edge port. (Personally, I configure the global portfast [and global bpduguard] command that Peter describes.)
We see little difference in PVST vs. RSTP operationally, but then individual port portfast (and backbone and uplink fasts) was also configured for PVST. Additionally, when there's intentional redundancy, it's either Etherchannel or L3. So, unsure our usage confirms RSTP is better, but this sort of answers your first question, in the sense we're not unhappy with it.
In answer to your second question, yes this is the sort of change you should make during a maintenance window. If you're doing large scale migrations, also keep in mind you can have both STPs in the same topology; i.e. they will inter-operate.
BTW, if you do go with global setting for portfast (and bpduguard), on some 3xxx switches, I've noticed the IOS will insert individual portfast command on applicable ports. I've also found, you can removes these individual port portfast command if you want to reduce the "clutter" in the config; i.e. portfast is still active on the port.
Note: when I mention PVST, ours is the default Cisco variant - which is actually PVST+ (?)
01-14-2013 03:04 AM
Thanks so much again another informative real world reply.
I will default my switches to RSTP. I also use BPDUGuard and Root Guard on my edge ports and want to introduce DHCP snooping (ealier post). Most ob my trunks I have upgraded to Etherchannels as I hate wasted bandwidth just sitting there.
It is nice to have a temlpate build like this as a standard.
Just one thing is RSTP enabled just on the Root or all?
01-14-2013 03:17 AM
Hello Andy
RSTP need to be enabled on all switches.
01-14-2013 04:35 AM
Hello Andy,
It does not make sense running both BPDU Guard and BPDU Root Guard on a single port. The BPDU Guard will force the port into err-disabled state when a BPDU is received. The Root Guard won't ever have a chance to have its turn
Best regards,
Peter
01-14-2013 05:14 AM
When you put it like that is makes absolute sense.
Thanks again.
