QOS 6513 SUP2 AVAYA VOIP
Bradford.berry
Hello All,
I am in need of some asistance, I have searched for days one forums and Google and am unable to find a sample config that doesnt use autoqos.
I need to enable QOS on a 6513 that i am using as a access switch.( loaded with
WS-X6148-45AF).  I am running SUP2MFSC2 with IOS and autoqos is not supported.
below is my IOS version and my requirements.
Requirements:
Trust CoS and DiffServ Value coming from Avaya equipments
DiffServ=46 for Audio and DiffServ=26 for Signaling
CoS=5 for Audio and CoS=3 for Signaling
I am running the following IOS:
IOS (tm) s222_rp Software (s222_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF17b, RELEASE SOFTWARE (fc1)
Sample Port config:( Vlan 709 = Data,Vlan 809=VOIP)
switchport
switchport access vlan 709
  switchport mode access
switchport voice vlan 809
no ip address
spanning-tree portfast
end
show mls qos
  QoS is enabled globally
  QoS ip packet dscp rewrite enabled globally
  Input mode for GRE Tunnel is Pipe mode
  Vlan or Portchannel(Multi-Earl) policies supported: Yes
  Egress policies supported: No
----- Module [2] -----
  QoS global counters:
    Total packets: 33034
    IP shortcut packets: 0
    Packets dropped by policing: 0
    IP packets with TOS changed by policing: 2349
    IP packets with COS changed by policing: 30
    Non-IP packets with COS changed by policing: 0
sho mls qos maps
   Normal Burst Policed-dscp map:                                  (dscp= d1d2)
     d1 :  d2 0  1  2  3  4  5  6  7  8  9
      0 :    00 01 02 03 04 05 06 07 08 09
      1 :    10 11 12 13 14 15 16 17 18 19
      2 :    20 21 22 23 24 25 26 27 28 29
      3 :    30 31 32 33 34 35 36 37 38 39
      4 :    40 41 42 43 44 45 46 47 48 49
      5 :    50 51 52 53 54 55 56 57 58 59
      6 :    60 61 62 63
   Maximum Burst Policed-dscp map:                                  (dscp= d1d2)
      6 :    60 61 62 63
   Dscp-cos map:                                  (dscp= d1d2)
      0 :    00 00 00 00 00 00 00 00 01 01
      1 :    01 01 01 01 01 01 02 02 02 02
      2 :    02 02 02 02 03 03 03 03 03 03
      3 :    03 03 04 04 04 04 04 04 04 04
      4 :    05 05 05 05 05 05 05 05 06 06
      5 :    06 06 06 06 06 06 07 07 07 07
      6 :    07 07 07 07
   Cos-dscp map:
         cos:   0  1  2  3  4  5  6  7
        dscp:   0  6 16 26 32 46 48 56
   IpPrecedence-dscp map:
      ipprec:   0  1  2  3  4  5  6  7
        dscp:   0  8 16 24 32 40 48 56
Your help will be greatly appreciated.
Brad
Fabienne Stephanoff
Hello Bradford,
I believe this type of card does support "mls qos trust dscp" under the interface config. Can you give that a try?
Fabienne
TAC
jkrysinski
I was wondering if you found a solution?  I am in the same boat as you and can't find anything on the Avaya site besides the autoqos.
James
