08-18-2018 07:13 AM - edited 03-08-2019 03:56 PM
Can anyone advice what the below refer to? I've tried researching online but can't find the specifics to some of the configs.
policy-map OUTPUT-POLICY
class OUTPUT-QUEUE-L1
priority level 1 percent 20
set dscp ef
class OUTPUT-QUEUE-L2
priority level 2 percent 10
set dscp af41
class MGMT-QUEUE
bandwidth remaining percent 5 (is this 5% of the remaining BW after priority queues 1/2 take 30%?)
queue-limit dscp cs2 percent 80 (how do these %'s work and what dscp would you recommend?)
queue-limit dscp cs3 percent 90
queue-limit dscp cs6 percent 100
queue-limit dscp cs7 percent 100
queue-buffers ratio 10
Also which queue would non tagged traffic fall under?
Thanks.
08-20-2018 02:55 AM
08-20-2018 07:46 AM - edited 08-20-2018 07:47 AM
"- non-tagged traffic ends up in the class-default queue"
Actually, we don't know from the OP information posted. Traffic not matched by a defined class would go to class-default. As OP didn't list the class-maps, we don't know where non-tagged traffic goes. Also, BTW, I assume by non-tagged OP means IP packets with a ToS setting of zero. (I.e. IP packets always have a ToS tag.)
"- yes 5% after the other queues take their bit."
An expanded yes - the 5% is based on bandwidth after LLQ, however, the 5% would only really be 5% if the other 95% of non-LLQ bandwidth is allocated (which it isn't, in OP), and in operation, the 5% minimum guarantee is only when all 100% of bandwidth has been configured and it's all being used at defined maximums.
What the bandwidth percentages really do, for non-LLQ traffic classes, it sets the dequeuing scheduling weight which is used relative to traffic classes.
"BUT: During congestion conditions, the traffic class is guaranteed bandwidth equal to the specified rate.
so this minimum is only in effect if no congestion occurs for this class, "
Actually, bandwidth guarantees are when there is congestion. I.e. above may have been intended to read:
Also, again, for the percentage to be provided, as the minimum, depends on overall policy configuration and actual traffic load against that policy. I.e. there's more involved than whether this class, alone, is congested or not.
08-21-2018 12:40 AM
08-20-2018 07:53 AM
