04-16-2012 05:29 AM - edited 03-07-2019 06:09 AM
I am trying to understand the implicit limit to the priority queue. I know you can define an explicit policer but if you don't I can't find out what the rate limit really is. thx again
04-16-2012 12:46 PM
The line rate.
04-17-2012 04:03 AM
Not sure I understand that if the priority is line rate yet you can specify bandwidth remaining for other classes how would there ever be any left
04-17-2012 06:05 AM
If you are sending line rate speed priority flows, it will use 100% of the link hence the recommendation for placing policers along with the priority command to avoid other flows being discarded.
Other platforms have the ability to allocate a value to the priority queue which in turn is an implicit policer.
04-17-2012 07:10 AM
but the documentation indicates that is you don't have a policer you can use bandwidth remaining
so
policy-map
class voice
priority
class whatever
bandwidth remaining percent 10
how can there be anything remaining if the priority takes up 100% of the available
thx
04-17-2012 10:11 AM
If you sent 100% priority traffic, there won't be remaining bandwidth guaranteed hence the 10% is null.
If you sent 90% priority traffic, then 10% will be guaranteed.
In very rare occasions, you will see priority using 100% of the traffic but it could happen due to misconfiguration
(i.e. assign priority class to high bandwidth flows).
Voice bearer, the default priority flow, does not demand a lot of bandwidth.
