QOS ,CBWFQ question
sarahr202
Level 5
Level 5
Hi everybody.
Thanks everyone in this forum who taught me so much and helped me get where i am today. I really wanted to visit this forum as often as i used to but this new job is keeping me on my toes :)
I have a question for you guys on CBWFQ.( we are only focusing CBWFQ not LLQ) I am getting conflicting statements to how the CBWFQ  queues are serviced.
The book  i am reading says service algorithm not published by cisco, while the videos lecture I have been watching says it is round robin.
I appreciate your help
Have a great weekend!
Reza Sharifi
Hi Sarah,
Long time no hear. Hope, you are doing well and the new job is challenging enough for you :)
According to below link (document) each class will have a FIFO queue assigned to it.
From the document:
Packets satisfying the match criteria for a class constitute the traffic for that class. A FIFO queue is reserved for each class, and traffic belonging to a class is directed to the queue for that class.
more info here:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfconmg.html#wp1001203
Reza
Reza Sharifi
Hi Sarah,
From the document:
more info here:
Reza
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Classes, excluding LLQ, are generally serviced relative to their weights relative to other active classes.
Given:
policy sample1
class A
bandwidth percent 25
class B
class C
bandwidth percent 50
If all classes were active, classes A and B should each get 25% and class C 50%, as expected.
However what if only classes A and B were active, or just classes B and C?
Classes A and B, if only ones active, would each get 50%.
Classes B and C, if only ones active, class B would get 1/3 and class C would get 2/3 (except on ASRs, where I understand "excess" bandwidth is proportioned differently).
What if given:
policy sample2
class A
bandwidth percent 10
class B
class C
bandwidth percent 20
My understanding is, policy sample2 would work like sample1 (except on ASRs).
What if given:
policy sample3
class A
class B
class class-default
fair-queue
If the above is pre-HQF, multiple flow queues will compete for bandwidth with the class queues for classes A and B.  Servicing is a bit complex, I recall someone had posted an article on the internet how queue weights are determined.  Also, BTW, part of the complexity, class-default FQ computes IP Precedence in weight determination.
policy sample4
class A
class B
class C
fair-queue
In HQF, any class can use FQ.  The aggregate of all the class flow queues is supposed to be "honor" the class bandwidth.  FQ in this case does not use IP Precedence.
Cisco doesn't always well/clearly document how CBWFQ services all its flows, but its operation does differ a bit on IOS version and/or platform.  (Personally, I find Cisco allowing different CBWFQ servicing, between pre-HQF and HQF CBWFQ, for the same exact syntax, disconcerning.)
