Highlighted
Beginner
QoS in L2 Switches 2960 and 4500
We have 3 layer LAN architecture, layer 1 of 6500(IP routing), layer 2 of 4500(L2 switch only), layer 3 of 2960(L2 Switch)
In a Single (2960 and 4500) Switch Port Avaya IP phone and PC are connected.
Now, the requirement is that, Qos need to be configured for Voice traffic and Data traffic should be in default class of service.
We plan to use COS value in Switch 4500 and 2960. We made a sample configuration as below
### For 4500 Switch
class-map match-all VOIP-Access-2MB
  match cos  3  5
class-map match-all VOIP-Uplink-20MB
  match cos  3  5
policy-map VOIP-Access-2MB
class VOIP-Access-2MB
    priority
    police cir 16000000    conform-action transmit     exceed-action transmit     violate-action drop
policy-map VOIP-Uplink-20MB
class VOIP-Uplink-20MB
   priority
   police 160000000    conform-action transmit     exceed-action transmit     violate-action drop
#####In interface :
Interface gig  x/x/x
Service policy  output  VOIP-Access-2MB
######For 2960 switch
mls qos srr-queue output cos-map queue 1 3 5
####interface configuration :
interface GigabitEthernet1/0/24
srr-queue bandwidth shape 20 0 0 0
mls qos trust cos
queue-set 2
priority-queue out
Please check these configurations are correct as per standard and if there is any other method of configuration?
What need to be configured in L3 Switch(6500)??
In 2960, it doesn't support ingress QoS, what impact it will make when compare to 4500? do users experiance any difference ??
Avaya is used here, will it create any issue in QoS??
Hope the requirment is understandable
Sankar..
1 REPLY 1
Highlighted
what we do for voice qos is this:
global config command: mls qos
uplink port config: mls qos trust
access port (with phone) config: auto qos voip cisco-phone
Content for Community-Ad
