QOS is CISCO NEXUS
AbdullahAkhtar6020
Frequent Visitor
Frequent Visitor
Hi, how to do  Qos Priority 7 for DSCP marking 45 46 47, in Nexus 3548
10 Replies 10
@AbdullahAkhtar6020
 You made this same question here few days ago.
https://community.cisco.com/t5/switching/how-to-setup-qos-priority-in-nexus-switch/td-p/5194171
The idea here is to people help each other but not sell service. You can get paid help anywhere else but I dont believe you are going to get here.
Hi Flavio,
Yes, the earlier response was not helpful. I can easily find online guides. I’m posting here to see if anyone can assist with my question.
Understand. I can assist you with your question.
Share the show running-config of your device as well as the IOS version please.
Hi as i mentioned earlier, nexus 3548 sw version 9.3.7.
required config qos-tos for dscp marking 45 46 46 and priority is 7, need proper syntax as i confused in guide
class-map match-any DSCP_45
match dscp 45
class-map match-any DSCP_46
match dscp 46
policy-map QoS_Policy
class DSCP_45
priority level 7
class DSCP_46
priority level 7
interface GigabitEthernetX
service-policy output QoS_Policy
There is no command in priority level how i configure priority 7?
Nexus 3548 (sw 9.3.7)
As earlier mentioned, i want to implement configuration qos-tos dscp marking 45 46 47 with priority 7
What was the complete syntax for nexus?
As i confused to read the complete guide 😞
AbdullahAkhtar6020
Frequent Visitor
Frequent Visitor
Hi, I want to set Qos Priority 7 for DSCP marking 45 46 47, in Nexus 3548
Hello @AbdullahAkhtar6020
To set QoS priority 7 for DSCP markings 45, 46, and 47 on a Nexus 3548, you need to configure a QoS policy map that matches the relevant DSCP values and assigns the desired priority level. First, create a class map to match the DSCP values, then configure a policy map to assign priority level 7 to the traffic matching those DSCP values, and finally apply this policy map to the relevant interface(s).
References:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3548/sw/92x/qos/configuration/guide/b-cisco-nexus-3548-nx-os-quality-of-service-configuration-guide-92x/b-cisco-nexus-3548-nx-os-qos-configuration-guide-92x_chapter_011.html
Best regards
Hi Can you make the configuration for me im bit confuse to read the complete document
