Highlighted
Beginner
QOS on Edge Switch (3750)
I have a 3750 I am trying to set up with QOS and I have come up with a set of commands I feel are accurate but I want to make sure that I am not leaving anything out.
I have edited the portion of the config that deals with QOS and have posted it below:
mls qos map cos-dscp 0 8 16 24 34 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2 4
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 25 32 34 36
mls qos srr-queue output dscp-map queue 2 threshold 1 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24 26
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 3 10 12 14
mls qos queue-set output 1 threshold 2 70 80 100 100
mls qos queue-set output 1 threshold 4 40 100 100 100
mls qos
class-map match-any Dez-Voice
  description Match any Dez Voice RTP
  match access-group name Dez-Voice-ACL
class-map match-any Dez-Signaling
  description Match any Dez-Call Signaling
  match access-group name Dez-Signaling-ACL
class-map match-any Dez-Video
  description Match any Dez Video RTP
  match access-group name Dez-Video-ACL
class-map match-any Dez-Data
  description Match any General Dez Data Traffic
  match access-group name Dez-Data-ACL
class-map match-any Dez-Collab
  description Match any Dez Collaboration Traffic
  match access-group name Dez-Collab-ACL
class-map match-any Default
  description Match any other traffic on LAN
  match access-group name ACL-Default-Traffic
policy-map Dez-QoS1-Policy
class Dez-Voice
   set dscp ef
class Dez-Signaling
   set dscp AF31
class Dez-Video
   set dscp AF41
class Dez-Data
   set dscp AF11
class Dez-Collab
   set dscp AF21
class Default
   set dscp default
ip access-list extended Dez-Voice
remark ~~~~~  Voice  ~~~~~
permit udp 10.99.224.0 0.0.31.255 any range 5000 5100
permit udp 10.99.224.0 0.0.31.255 207.22.163.64 0.0.0.224 range 49152 65535
permit ip 10.99.224.0 0.0.31.255 any dscp ef
permit udp 162.99.224.0 0.0.31.255 any range 5000 5100
permit udp 162.99.224.0 0.0.31.255 207.22.163.64 0.0.0.224 range 49152 65535
permit ip 162.99.224.0 0.0.31.255 any dscp ef
ip access-list extended Dez-Signaling
remark ~~~~~  Signaling ~~~~~
permit tcp 10.99.224.0 0.0.31.255 any range 5060 5061
permit udp 10.99.224.0 0.0.31.255 any range 5060 5061
permit ip 10.99.224.0 0.0.31.255 any dscp AF31
permit tcp 162.99.224.0 0.0.31.255 any range 5060 5061
permit udp 162.99.224.0 0.0.31.255 any range 5060 5061
permit ip 162.99.224.0 0.0.31.255 any dscp AF31
ip access-list extended Dez-Video
remark ~~~~~  Video ~~~~~
permit udp 10.99.224.0 0.0.31.255 any range 6000 6100
permit ip 10.99.224.0 0.0.31.255 any dscp AF41
permit udp 162.99.224.0 0.0.31.255 any range 6000 6100
permit ip 162.99.224.0 0.0.31.255 any dscp AF41
ip access-list extended Dez-Data
remark ~~~~~  Data ~~~~~
permit tcp 10.99.224.0 0.0.31.255 207.22.163.90 0.0.0.0 eq 443 80
permit tcp 10.99.224.0 0.0.31.255 207.22.163.91 0.0.0.0 eq 443 80
permit ip 10.99.224.0 0.0.31.255 any dscp AF11
permit tcp 162.99.224.0 0.0.31.255 207.22.163.90 0.0.0.0 eq 443 80
permit tcp 162.99.224.0 0.0.31.255 207.22.163.91 0.0.0.0 eq 443 80
permit ip 162.99.224.0 0.0.31.255 any dscp AF11
ip access-list extended Dez-Collab
remark ~~~~~  Collaboration ~~~~~
permit tcp 10.99.224.0 0.0.31.255 207.22.163.64.0 0.0.0.0 eq 443 80  5222 5223
permit ip 10.99.224.0 0.0.31.255 any dscp AF21
permit tcp 162.99.224.0 0.0.31.255 207.22.163.64.0 0.0.0.0 eq 443 80  5222 5223
permit ip 162.99.224.0 0.0.31.255 any dscp AF21
ip access-list extended Default
remark ~~~~~  Default  ~~~~~
permit ip any any
Desmond
0 REPLIES 0
Content for Community-Ad
