QoS Policy not activating
Brian Green
I am having a problem getting a QoS policy to activate.
I have a 2921 ISR router with several VRFs defined on it, and several DMVPNs.  What I'm trying to do is enact QoS using a simple policy - I would think the place to apply it would be the router egress interface since that interface doesn't use VRFs or DMVPNs.  When I view the policy using "show policy-map interface" the number of packets in the class stay at 0.
I have an Extended Access List:
ip access-list extended name Test1_acl
 permit ip X.X.0.0 0.0.255.255 X.X.0.0 0.0.255.255
where X.X.0.0 is the subnet of nodes within one of the VRFs going to a destination over a DMVPN Tunnel.
And that connects to a Class Map:
class-map Test1_cm
 match access-group Test1_acl
which connects to a Policy Map:
policy-map Test1_pm
 class Test1_cm
  bandwidth percent 25
  set dscp af31
I've applied this to an interface:
interface GigabitEthernet0/2
 ip address Y.Y.224.1 255.255.255.0
 service-policy output Test1_pm
When I issue a ping from a workstation on the X.X.0.0 subnet, the packet (as I underdstand it) goes to the 2921 router, enters the DMVPN, then gets sent out on g0/2 - but the Source and Destination IPs are left unchanged.
What I am seeing when running an infinite png is all the packets go into the default class and none into Test1_cm.
Any ideas how I can make this work?
Brian
Joseph W. Doherty
You policy is on the physical egress interface?  If so, what IPs are you matching against, tunnel end-points, or pre-DMVPN source/destination IPs?
I managed to find a working solution - I created a simple policy map to apply the DSCP markings to the packet on its way IN to the router - so the QoS policy on the output interface can use that as the differentiator.  Not elegant, but (I think) it works.
Thanks!
Brian
Yes, that could be a solution because generally original packet's ToS byte is copied to the encapsulated header's ToS byte.
Otherwise, without using qos pre-classify (don't recall whether it works with DMVPN), egress interface QoS policies "see" the encapsulated header.
I was looking at some captured packets - the IPv4 Header had the DSCP field set properly once I changed it on the ingress interface.  So it does propogate it through.  I do have the "qos pre-classify" command set on all my VPN tunnels.
Brian
