Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
TS40 by Level 1
  • 108 Views
  • 1 replies
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
oowJ by Level 1
  • 167 Views
  • 4 replies
Hello everyone!I'm not a network engineer but as a subsystem (kernel + filesystem) engineer I know the network concept.Few months ago, I designed a DMZ and configured my 2 node VPC with 6 rack switch.Everything was smoothly working but I started to s...
Ozy by Level 1
  • 102 Views
  • 1 replies
On Nexus 7000s I want to limit bandwidth of particular IP. I can do this using proper configuratio of IP ACL, policy map and class map. But what if I dont have information on interface?  Can I apply bandwidth control for particular IP without knowing...
liveshell by Level 1
  • 952 Views
  • 5 replies
I have a less then a dozen Cisco 3850 switches that I am working on.  I need to configure 802.1x authentication.  The issue is the switches are reaching out to Cisco ACS and I need to set up radius server to enable 802.1x.  The Cisco ACS I found out ...
John N by Level 1
  • 221 Views
  • 6 replies
Am trying to create a new local account on a Nexus 3048 so I can SSH to it if my Radius server doesn't work.  Normally, I log in with my AD account which the switch uses Radius for authentication with that.  However, when I run the command to create ...
mramj499 by Level 1
  • 74 Views
  • 1 replies
Dear community I am getting into NetFlow a little bit deeper but cannot get my head around sampling. All i understand so far: We can configure deterministic sampling, that uses a hardware sampler per interface, limiting the maximum number of monitori...
Hi All , I am in the testing phase of migrating to a 9300. So far I have done the below.3850 running 16.3.6   and 9300 updated 17.09.04aI have copied the start-up config to the 9300 - all looks ok apart from the usual ip routes , some interfaces not ...
machine23 by Level 1
  • 108 Views
  • 2 replies
Resolved! Networking
Hi everyone, I have a Cisco catalyst C1200-24P-4X switch, and I want to enable stacked VLAN configuration on it. Does it can support the feature?
moges1 by Level 1
  • 123 Views
  • 1 replies
