04-24-2019 09:34 AM
Hey All,
I'm looking to upgrade my 4507R with is configured in a VSS mode with quad sup running SUP7L-E
The code i'm currently running is 03.04.00.SG and I'm moving to 03.08.07E.
does anyone have documentation on how to perform this upgrade.
Solved! Go to Solution.
04-24-2019 10:28 AM
below guide help you to upgrade :
make sure you read the release notes.
04-24-2019 10:28 AM
04-24-2019 05:08 PM
@balaji.bandi wrote:
Had a look at this document, particularly the "Manual Software Upgrade Process" section and I am "not impressed". There are a number of important steps missing:
The steps that we have came up with is, by far, better.
04-25-2019 12:10 AM
Agreed, in this Fast world changes happens every few months, I have given the document for high level reference. also suggested to read the release notes also which covers ROMMON Upgrade.
For ORginal post user - if you required further assistance or any doubt please let us know.
Below document was the latest for refernce - which covers.
Release notess : ( if you not got it yet)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-38xe-4500e.html
04-25-2019 05:48 AM
Ultimately I will be opening a TAC case and having them explicitly tell me the correct method and steps for this upgrade.
04-24-2019 05:00 PM
