Question about etherchannel load balancing
Jason Dance
Hi fellow forum members.
In one of my networks I use etherchannel between my access layer (mainly 3750s) and distribution layer (6500).  Right now I am using a load-balance method of src-mac, and I'd like to switch to src-dst-ip.
When I make the change, do both switches participating in the port-channel need to have the same load-balance method configured at the same time?  Or is it possible that I can change one first and do the other at a later stage?
Jason
Jon Marshall
Jason
Each end of the etherchannel can use whatever load balancing algorithm makes the most sense so no they do not need to match.
Jon
Jon Marshall
Jason
Jon
Thanks Jon, much appreciated!
