Question about line vty
mh.gorjizadeh
Hi there
i have a question
in Cisco ruter and switch we have line vty and it can be line vty <0-15> <0-15> does it mean we have 16*16=256 vty?
are they just used for telnet and ssh ?
well i am kind of beginner so i f some dude explaint that for me i t will be perfect .
Daniel McDavid
In that case, you have 16 vty lines. You can configure them one at a time (line vty 0) or all sixteen (line vty 0 15) at once.
Thank you for your answer.
but we can use this command and IOS consider it as a correct command:
line vty 0 1
or        1  3
or        4 15
or.............
then what is first digint and second digit?
Think of it like an interface range command. You have 16 virtual telephony (VTY) lines available:
line vty 0
line vty 1
line vty 14
line vty 15
The first digit represents the first line in the range and the second is the last line in the range. Unless you have a specific need to, just configure them all at once with the 'line vty 0 15' command.
Oh i got it ,so they are ranges.
Thank you Sir for your help.
