Community Helping Community
457
Beginner
Question about Stacking
Hello there.
I'm facing some issue with stacking practice with two ws_3850
                                             H/W   Current
Switch#   Role    Mac Address     Priority Version  State
*1       Active   3c5e.c353.9380     10     V04     Ready
 2       Standby  547c.69df.a180     14     V04     Ready
 9       Member   0000.0000.0000     0      0       Unprovisioned       <---- how to remove this from list???
I've tried
'no switch 9 provision'
'eload slot 9
Switch 9 is not part of the stack'
Is there any way to fix this ?? and right step to remove stack member??
and.... how to switchover active role ? by reloading? any way by using command ?
What if there are five switches.
Five switches console ports always take me master(active) swich.
how to figure out which switch is connected directly to my console cable??
Thank you : )
1 REPLY 1
VIP Expert
Hi,Is there any way to fix
The right way is to use the command you have already used (no switch 9 provision) and save the config
Since you are still seeing the switch, you may have to reload the stack.
looking at your stack it appeaser that switch 2 has higher priority than the active switch. If you reboot the switch switch 2 should become the master since its priority is 14.
Rebooting cause downtime so make sure to do it during an outage
Content for Community-Ad
