Question in ACS radius ports and how test connectivity between router
Dr.X
Level 2
Level 2
hi all
im asking here about default ports used in cisco acs for radius protocol
is it 1812 and 1813 ???
or there is another ports ??
Q2-
how to test connectivity between ACS "server aaa"  and the router "client aaa " ??????
Q3-
can anyone give me simple config on router for radius protocol to connect acs based on radius protocol ?
regards
Reza Sharifi
The default UDP port for Radius is 1812.
If you have already cconfigured the Radius, than you can test it by trying to connect to your devices.
What deives are you using?
here is the Radius config example for Nexus 5ks
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/sec_radius.html
Collin Clark
The default authentictaion port is 1812 and the default accounting port is 1813.
Here's an example config-
aaa new-model
aaa group server radius ACME-RADIUS
server-private 192.168.1.5 auth-port 1812 acct-port 1813 key SeCrEtPaSsWoRd
aaa authentication login default local
aaa authentication login ACME-AAA group ACME-RADIUS local
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group ACME-RADIUS
line vty 0 4
login authentication ACME-AAA
You can test with-
test aaa group radius server 192.168.1.5 mmessier St@nleyCup
where mmessier is your username and the password is St@nleyCup
