08-20-2014 07:40 AM - edited 03-07-2019 08:27 PM
hi all ,
i need to know and get deep understand about wts power dissipation in router 7600.
here is my condfig :
Gateway7600#sh power
system power redundancy mode = redundant
system power total = 2669.10 Watts (63.55 Amps @ 42V)
system power used = 367.50 Watts ( 8.75 Amps @ 42V)
system power available = 2301.60 Watts (54.80 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 PWR-2700-AC/4 2669.10 63.55 OK OK on
2 PWR-2700-AC/4 2669.10 63.55 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 FAN-MOD-4HS 57.54 1.37 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-SUP32-GE-3B 154.98 3.69 154.98 3.69 on on
2 (Redundant Sup) - - 154.98 3.69 - -
i see that total is 8.75 A from the router ... but i want to ask , how about the 8.75 ??
is it from 1 power supply ? or from the two power supplies ?
any clarification about the 8.75 A ???
regards
08-20-2014 11:52 AM
Hi Ahmed,
If you see below output, we have two power supply and each is supplying 63.55 Amp.
Out of which 8.75 Amps is used and 54.80 Amps is available which is giving details for one power supply only. And we have 1:1 power redundancy so all components on router can consume power maximum from one power supply only so in case one fails other should be able to suffice all power needs
How router calculated 8.75 Amps total consumption :
It is sum of power consumed by primary sup, secondary sup and FAN = 3.69 + 3.69 + 1.37 = 8.75
Pls dont forget to rate helpful posts
Akash
