Switching
Get 20% off switches when you combine Cisco solutions
Labels
hello every body what is the differentsfp-10/25g-lr-s (10-3251-01) and sfp-10/25g-lr-s (10-3251-02)
nagy by Level 1
  • 97 Views
  • 2 replies
Hello,Studying for my CCNA and I thought I'd practice some basic configurations, such as router on a stick. I setup 4 PC's (each representing an imaginary number of hosts) each with a vlan attached to a switch leading to a router, with the link betwe...
At Cisco Live I was able to get into a lab where the advisor showed a feature that I cannot find any information on how to implement or use. It was quick example. On the switch you can enable a packet trace and actually watch the packet traverse from...
Resolved! Cisco SG350-28 LAG
Hi allI'm attempting to use 4 cisco SG350-28 switches connected around 100 meters apart. 3 switches will connect to 1 "central switch", each using a LAG (the far away switches are using SFP fiber modules). I have this setup and all seems to be workin...
sam7611 by Level 1
  • 106 Views
  • 2 replies
We would like to purchase a cisco switch which need to be under TAA compliance. Please provide the TAA compliant statement (document), if the below mentionedCisco IB-C9300-48T-A and IB-C9300-24T-A is under Trade Agreements Act (TAA) compliance.
