Highlighted
Beginner
Quick Question about 3650 8port power consumption
Hello there,
I bought a used cisco 3560 8ports POE switch from ebay and i received it without its power cord. According to its power consumption, which is stated on the back of the switch right below the power jack, it needs 2.5A.
I have an extra power cord but its fuse is 10A.
Does that mean the cable will allow more amber to enter and burn the switch? or should i be fine?
2 REPLIES 2
Highlighted
Hall of Fame Community Legend
You can go to any electronic or computer shop and purchase a generic power cable.
I am not sure what is the technical term but in Australia this cable is called a "jug cable".
Highlighted
Hall of Fame Expert
I guess you are talking about 8 port 3560 and not 3650.
anyway, the power cord for a 3560 is C5-15/13.  It is the same power cord as the one for a PC or printer, etc...
Content for Community-Ad
