"Enqueued to process level.” was seen in router
vasanth77
     I have configured Netflow export in our router and its returned an error
Also I read that that flow exported by the interface was processed by processor?
How to avoid this error?
what need to be done and what are all things i have to check for this in router?
what is the issue?
Ganesh Hariharan
what is the issue?
Hi Vasanth,
Is router is running Release 12.4T and 12.4(4)XD2, If yes then there is no workaround for this bug as bug details.
So I need to upgrade the IOS to resolve this ,Is it your suggestion?
Hi Vasanth,
So you are running the above codes, As per bug details the fixed realses are 12.4(10.5)T and later.
Hope it Helps..
-GI
Rate Helpful Posts
Hi Ganesh,
                 Please see below for information of the router ,any help would be appreciated.
NOC#sh ver
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 12.4(24)T2,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 19-Oct-09 22:53 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(12),
INMAA-PULSE-TNAGAR-NOC uptime is 1 week, 5 days, 3 hours, 51 minutes
System image file is "disk2:c7200-advipservicesk9-mz.124-24.T2.bin"
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
NOC#
NOC#show ip interface gi0/1
GigabitEthernet0/1 is up, line protocol is up
  Internet address is 27.251.112.162/30
  Broadcast address is 255.255.255.255
  Address determined by setup command
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is enabled
  IP CEF switching is enabled
  IP Flow switching turbo vector
  IP Flow CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, Flow cache, CEF, Full Flow, Subint Flow
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
NOC#show ip interface gi0/2
GigabitEthernet0/2 is up, line protocol is up
  Internet address is 115.248.4.221/30
  MTU is 1500 bytes
NOC#show ip interface gi0/3
GigabitEthernet0/3 is up, line protocol is up
  Internet protocol processing disabled
NOC#show ip flow export
Flow export v5 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       103.249.204.69 (GigabitEthernet0/3.759)
    Destination(1)  103.249.204.70 (2055)
  Version 5 flow records
  1828692617 flows exported in 60956422 udp datagrams
  2969 flows failed due to lack of export packet
  6670 export packets were sent up to process level
  0 export packets were dropped due to no fib
  26550 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
NOC#show ip cef
Prefix              Next Hop             Interface
0.0.0.0/0           27.251.112.161       GigabitEthernet0/1
0.0.0.0/32          receive
23.96.112.53/32     115.248.4.222        GigabitEthernet0/2
27.251.112.160/30   attached             GigabitEthernet0/1
27.251.112.160/32   receive
27.251.112.161/32   27.251.112.161       GigabitEthernet0/1
27.251.112.162/32   receive
27.251.112.163/32   receive
43.254.108.0/24     attached             Null0
43.254.108.0/30     attached             GigabitEthernet0/3.800
43.254.108.0/32     receive
43.254.108.1/32     receive
43.254.108.3/32     receive
43.254.108.104/29   103.249.207.6        GigabitEthernet0/3.801
43.254.109.0/24     attached             Null0
43.254.109.0/30     attached             GigabitEthernet0/3.800
43.254.109.0/32     receive
43.254.109.1/32     receive
43.254.109.3/32     receive
43.254.109.12/30    attached             GigabitEthernet0/3.800
43.254.109.12/32    receive
43.254.109.13/32    receive
43.254.109.15/32    receive
43.254.109.16/30    103.249.207.6        GigabitEthernet0/3.801
43.254.110.0/24     attached             Null0
43.254.110.0/30     attached             GigabitEthernet0/3.800
43.254.110.0/32     receive
43.254.110.1/32     receive
43.254.110.3/32     receive
43.254.110.4/30     103.249.206.206      GigabitEthernet0/3.756
43.254.110.8/30     103.249.206.206      GigabitEthernet0/3.756
43.254.110.12/30    103.249.206.206      GigabitEthernet0/3.756
43.254.111.0/24     attached             Null0
43.254.111.64/30    103.249.204.30       GigabitEthernet0/3.796
43.254.111.84/30    103.249.204.30       GigabitEthernet0/3.796
43.254.111.100/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.104/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.112/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.116/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.120/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.124/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.128/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.132/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.136/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.140/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.144/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.152/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.156/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.160/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.164/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.168/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.172/30   103.249.204.30       GigabitEthernet0/3.796
43.254.111.176/29   103.249.204.30       GigabitEthernet0/3.796
43.254.111.184/30   103.249.204.30       GigabitEthernet0/3.796
50.16.217.194/32    115.248.4.222        GigabitEthernet0/2
64.29.151.221/32    115.248.4.222        GigabitEthernet0/2
64.79.161.110/32    115.248.4.222        GigabitEthernet0/2
94.205.250.164/32   115.248.4.222        GigabitEthernet0/2
103.3.230.0/24      attached             Null0
103.3.230.0/30      attached             GigabitEthernet0/3.800
103.3.230.0/32      receive
103.3.230.1/32      receive
103.3.230.3/32      receive
103.3.230.4/30      103.249.207.6        GigabitEthernet0/3.801
103.3.230.16/28     103.3.230.34         GigabitEthernet0/3.141
103.3.230.32/30     attached             GigabitEthernet0/3.141
103.3.230.32/32     receive
103.3.230.33/32     receive
103.3.230.34/32     103.3.230.34         GigabitEthernet0/3.141
103.3.230.35/32     receive
103.3.230.36/30     attached             GigabitEthernet0/3.123
103.3.230.36/32     receive
103.3.230.37/32     receive
103.3.230.38/32     103.3.230.38         GigabitEthernet0/3.123
103.3.230.39/32     receive
103.3.230.224/29    attached             GigabitEthernet0/3.757
103.3.230.224/32    receive
103.3.230.225/32    receive
103.3.230.229/32    103.3.230.229        GigabitEthernet0/3.757
103.3.230.231/32    receive
103.3.231.0/24      attached             Null0
103.3.231.0/30      attached             GigabitEthernet0/3.800
103.3.231.0/32      receive
103.3.231.1/32      receive
103.3.231.3/32      receive
103.249.80.0/24     attached             Null0
103.249.80.0/30     attached             GigabitEthernet0/3.800
103.249.80.0/32     receive
103.249.80.1/32     receive
103.249.80.3/32     receive
103.249.80.4/30     attached             GigabitEthernet0/3.163
103.249.80.4/32     receive
103.249.80.5/32     receive
103.249.80.6/32     103.249.80.6         GigabitEthernet0/3.163
103.249.80.7/32     receive
103.249.80.12/30    attached             GigabitEthernet0/3.128
103.249.80.12/32    receive
103.249.80.13/32    receive
103.249.80.14/32    103.249.80.14        GigabitEthernet0/3.128
103.249.80.15/32    receive
103.249.80.16/28    103.249.80.6         GigabitEthernet0/3.163
103.249.80.32/30    attached             GigabitEthernet0/3.85
103.249.80.32/32    receive
103.249.80.33/32    receive
103.249.80.34/32    103.249.80.34        GigabitEthernet0/3.85
103.249.80.35/32    receive
103.249.80.36/30    attached             GigabitEthernet0/3.54
103.249.80.36/32    receive
103.249.80.37/32    receive
103.249.80.38/32    103.249.80.38        GigabitEthernet0/3.54
103.249.80.39/32    receive
103.249.80.40/29    103.249.204.30       GigabitEthernet0/3.796
103.249.80.48/29    103.249.80.62        GigabitEthernet0/3.20
103.249.80.56/30    attached             GigabitEthernet0/3.92
103.249.80.56/32    receive
103.249.80.57/32    receive
103.249.80.58/32    103.249.80.58        GigabitEthernet0/3.92
103.249.80.59/32    receive
103.249.80.60/30    attached             GigabitEthernet0/3.20
103.249.80.60/32    receive
103.249.80.61/32    receive
103.249.80.62/32    103.249.80.62        GigabitEthernet0/3.20
103.249.80.63/32    receive
103.249.80.64/30    103.249.204.30       GigabitEthernet0/3.796
103.249.80.68/30    attached             GigabitEthernet0/3.78
103.249.80.68/32    receive
103.249.80.69/32    receive
103.249.80.70/32    103.249.80.70        GigabitEthernet0/3.78
103.249.80.71/32    receive
103.249.80.72/30    103.249.204.30       GigabitEthernet0/3.796
103.249.80.76/30    attached             GigabitEthernet0/3.67
103.249.80.76/32    receive
103.249.80.77/32    receive
103.249.80.78/32    103.249.80.78        GigabitEthernet0/3.67
103.249.80.79/32    receive
103.249.80.80/29    attached             GigabitEthernet0/3.50
103.249.80.80/32    receive
103.249.80.81/32    receive
103.249.80.82/32    103.249.80.82        GigabitEthernet0/3.50
103.249.80.87/32    receive
103.249.80.88/30    attached             GigabitEthernet0/3.32
103.249.80.88/32    receive
103.249.80.89/32    receive
103.249.80.90/32    103.249.80.90        GigabitEthernet0/3.32
103.249.80.91/32    receive
103.249.80.92/30    attached             GigabitEthernet0/3.43
103.249.80.92/32    receive
103.249.80.93/32    receive
103.249.80.94/32    103.249.80.94        GigabitEthernet0/3.43
103.249.80.95/32    receive
103.249.80.96/30    attached             GigabitEthernet0/3.15
103.249.80.96/32    receive
103.249.80.97/32    receive
103.249.80.98/32    103.249.80.98        GigabitEthernet0/3.15
103.249.80.99/32    receive
103.249.80.100/30   attached             GigabitEthernet0/3.850
103.249.80.100/32   receive
103.249.80.101/32   receive
103.249.80.102/32   103.249.80.102       GigabitEthernet0/3.850
103.249.80.103/32   receive
103.249.80.104/29   103.249.82.6         GigabitEthernet0/3.22
103.249.80.112/29   attached             GigabitEthernet0/3.44
103.249.80.112/32   receive
103.249.80.113/32   receive
103.249.80.114/32   103.249.80.114       GigabitEthernet0/3.44
103.249.80.119/32   receive
103.249.80.120/30   attached             GigabitEthernet0/3.182
103.249.80.120/32   receive
103.249.80.121/32   receive
103.249.80.122/32   103.249.80.122       GigabitEthernet0/3.182
103.249.80.123/32   receive
103.249.80.124/30   attached             GigabitEthernet0/3.52
103.249.80.124/32   receive
103.249.80.125/32   receive
103.249.80.126/32   103.249.80.126       GigabitEthernet0/3.52
103.249.80.127/32   receive
103.249.80.136/30   attached             GigabitEthernet0/3.155
103.249.80.136/32   receive
103.249.80.137/32   receive
103.249.80.138/32   103.249.80.138       GigabitEthernet0/3.155
103.249.80.139/32   receive
103.249.80.140/30   attached             GigabitEthernet0/3.156
103.249.80.140/32   receive
103.249.80.141/32   receive
103.249.80.142/32   103.249.80.142       GigabitEthernet0/3.156
103.249.80.143/32   receive
103.249.80.144/30   attached             GigabitEthernet0/3.400
103.249.80.144/32   receive
103.249.80.145/32   receive
103.249.80.146/32   103.249.80.146       GigabitEthernet0/3.400
103.249.80.147/32   receive
103.249.80.148/30   attached             GigabitEthernet0/3.444
103.249.80.148/32   receive
103.249.80.149/32   receive
103.249.80.150/32   103.249.80.150       GigabitEthernet0/3.444
103.249.80.151/32   receive
103.249.80.152/29   attached             GigabitEthernet0/3.445
103.249.80.152/32   receive
103.249.80.153/32   receive
103.249.80.154/32   103.249.80.154       GigabitEthernet0/3.445
103.249.80.159/32   receive
103.249.80.160/29   103.249.80.150       GigabitEthernet0/3.444
103.249.80.168/30   attached             GigabitEthernet0/3.45
103.249.80.168/32   receive
103.249.80.169/32   receive
103.249.80.170/32   103.249.80.170       GigabitEthernet0/3.45
103.249.80.171/32   receive
103.249.80.172/30   attached             GigabitEthernet0/3.68
103.249.80.172/32   receive
103.249.80.173/32   receive
103.249.80.174/32   103.249.80.174       GigabitEthernet0/3.68
103.249.80.175/32   receive
103.249.80.184/29   103.249.80.146       GigabitEthernet0/3.400
103.249.80.192/29   attached             GigabitEthernet0/3.41
103.249.80.192/32   receive
103.249.80.193/32   receive
103.249.80.195/32   103.249.80.195       GigabitEthernet0/3.41
103.249.80.199/32   receive
103.249.80.204/30   attached             GigabitEthernet0/3.57
103.249.80.204/32   receive
103.249.80.205/32   receive
103.249.80.206/32   103.249.80.206       GigabitEthernet0/3.57
103.249.80.207/32   receive
103.249.80.208/29   103.249.82.66        GigabitEthernet0/3.10
103.249.80.216/29   attached             GigabitEthernet0/3.96
103.249.80.216/32   receive
103.249.80.217/32   receive
103.249.80.218/32   103.249.80.218       GigabitEthernet0/3.96
103.249.80.219/32   103.249.80.219       GigabitEthernet0/3.96
103.249.80.220/32   103.249.80.220       GigabitEthernet0/3.96
103.249.80.223/32   receive
103.249.80.224/29   attached             GigabitEthernet0/3.14
103.249.80.224/32   receive
103.249.80.225/32   receive
103.249.80.229/32   103.249.80.229       GigabitEthernet0/3.14
103.249.80.231/32   receive
103.249.80.232/30   attached             GigabitEthernet0/3.55
103.249.80.232/32   receive
103.249.80.233/32   receive
103.249.80.234/32   103.249.80.234       GigabitEthernet0/3.55
103.249.80.235/32   receive
103.249.80.248/29   attached             GigabitEthernet0/3.192
103.249.80.248/32   receive
103.249.80.249/32   receive
103.249.80.254/32   103.249.80.254       GigabitEthernet0/3.192
103.249.80.255/32   receive
103.249.81.0/24     attached             Null0
103.249.81.0/30     attached             GigabitEthernet0/3.800
103.249.81.0/32     receive
103.249.81.1/32     receive
103.249.81.3/32     receive
103.249.81.4/30     attached             GigabitEthernet0/3.121
103.249.81.4/32     receive
103.249.81.5/32     receive
103.249.81.6/32     103.249.81.6         GigabitEthernet0/3.121
103.249.81.7/32     receive
103.249.81.8/30     103.249.204.30       GigabitEthernet0/3.796
103.249.81.12/30    attached             GigabitEthernet0/3.97
103.249.81.12/32    receive
103.249.81.13/32    receive
103.249.81.14/32    103.249.81.14        GigabitEthernet0/3.97
103.249.81.15/32    receive
103.249.81.16/29    attached             GigabitEthernet0/3.106
103.249.81.16/32    receive
103.249.81.17/32    receive
103.249.81.18/32    103.249.81.18        GigabitEthernet0/3.106
103.249.81.19/32    103.249.81.19        GigabitEthernet0/3.106
103.249.81.20/32    103.249.81.20        GigabitEthernet0/3.106
103.249.81.21/32    103.249.81.21        GigabitEthernet0/3.106
103.249.81.22/32    103.249.81.22        GigabitEthernet0/3.106
103.249.81.23/32    receive
103.249.81.24/30    attached             GigabitEthernet0/3.88
103.249.81.24/32    receive
103.249.81.25/32    receive
103.249.81.26/32    103.249.81.26        GigabitEthernet0/3.88
103.249.81.27/32    receive
103.249.81.28/30    attached             GigabitEthernet0/3.79
103.249.81.28/32    receive
103.249.81.29/32    receive
103.249.81.30/32    103.249.81.30        GigabitEthernet0/3.79
103.249.81.31/32    receive
103.249.81.32/29    attached             GigabitEthernet0/3.105
103.249.81.32/32    receive
103.249.81.33/32    receive
103.249.81.34/32    103.249.81.34        GigabitEthernet0/3.105
103.249.81.39/32    receive
103.249.81.40/30    attached             GigabitEthernet0/3.136
103.249.81.40/32    receive
103.249.81.41/32    receive
103.249.81.42/32    103.249.81.42        GigabitEthernet0/3.136
103.249.81.43/32    receive
103.249.81.44/30    attached             GigabitEthernet0/3.33
103.249.81.44/32    receive
103.249.81.45/32    receive
103.249.81.46/32    103.249.81.46        GigabitEthernet0/3.33
103.249.81.47/32    receive
103.249.81.56/29    103.249.207.6        GigabitEthernet0/3.801
103.249.81.64/29    attached             GigabitEthernet0/3.56
103.249.81.64/32    receive
103.249.81.65/32    receive
103.249.81.66/32    103.249.81.66        GigabitEthernet0/3.56
103.249.81.71/32    receive
103.249.81.72/29    103.249.207.6        GigabitEthernet0/3.801
103.249.81.84/30    attached             GigabitEthernet0/3.24
103.249.81.84/32    receive
103.249.81.85/32    receive
103.249.81.86/32    103.249.81.86        GigabitEthernet0/3.24
103.249.81.87/32    receive
103.249.81.92/30    attached             GigabitEthernet0/3.35
103.249.81.92/32    receive
103.249.81.93/32    receive
103.249.81.94/32    103.249.81.94        GigabitEthernet0/3.35
103.249.81.95/32    receive
103.249.81.96/29    attached             GigabitEthernet0/3.114
103.249.81.96/32    receive
103.249.81.97/32    receive
103.249.81.103/32   receive
103.249.81.104/30   attached             GigabitEthernet0/3.113
103.249.81.104/32   receive
103.249.81.105/32   receive
103.249.81.106/32   103.249.81.106       GigabitEthernet0/3.113
103.249.81.107/32   receive
103.249.81.108/30   attached             GigabitEthernet0/3.125
103.249.81.108/32   receive
103.249.81.109/32   receive
103.249.81.110/32   103.249.81.110       GigabitEthernet0/3.125
103.249.81.111/32   receive
103.249.81.112/29   attached             GigabitEthernet0/3.112
103.249.81.112/32   receive
103.249.81.113/32   receive
103.249.81.114/32   103.249.81.114       GigabitEthernet0/3.112
103.249.81.115/32   103.249.81.115       GigabitEthernet0/3.112
103.249.81.119/32   receive
103.249.81.120/30   103.249.81.106       GigabitEthernet0/3.113
103.249.81.124/30   attached             GigabitEthernet0/3.31
103.249.81.124/32   receive
103.249.81.125/32   receive
103.249.81.126/32   103.249.81.126       GigabitEthernet0/3.31
103.249.81.127/32   receive
103.249.81.128/29   attached             GigabitEthernet0/3.167
103.249.81.128/32   receive
103.249.81.129/32   receive
103.249.81.135/32   receive
103.249.81.144/30   attached             GigabitEthernet0/3.46
103.249.81.144/32   receive
103.249.81.145/32   receive
103.249.81.146/32   103.249.81.146       GigabitEthernet0/3.46
103.249.81.147/32   receive
103.249.81.152/29   attached             GigabitEthernet0/3.19
103.249.81.152/32   receive
103.249.81.153/32   receive
103.249.81.154/32   103.249.81.154       GigabitEthernet0/3.19
103.249.81.157/32   103.249.81.157       GigabitEthernet0/3.19
103.249.81.159/32   receive
103.249.81.160/29   attached             GigabitEthernet0/3.158
103.249.81.160/32   receive
103.249.81.161/32   receive
103.249.81.162/32   103.249.81.162       GigabitEthernet0/3.158
103.249.81.163/32   103.249.81.163       GigabitEthernet0/3.158
103.249.81.167/32   receive
103.249.81.168/29   attached             GigabitEthernet0/3.73
103.249.81.168/32   receive
103.249.81.169/32   receive
103.249.81.170/32   103.249.81.170       GigabitEthernet0/3.73
103.249.81.171/32   103.249.81.171       GigabitEthernet0/3.73
103.249.81.172/32   103.249.81.172       GigabitEthernet0/3.73
103.249.81.173/32   103.249.81.173       GigabitEthernet0/3.73
103.249.81.174/32   103.249.81.174       GigabitEthernet0/3.73
103.249.81.175/32   receive
103.249.81.184/30   attached             GigabitEthernet0/3.62
103.249.81.184/32   receive
103.249.81.185/32   receive
103.249.81.186/32   103.249.81.186       GigabitEthernet0/3.62
103.249.81.187/32   receive
103.249.81.188/30   attached             GigabitEthernet0/3.39
103.249.81.188/32   receive
103.249.81.189/32   receive
103.249.81.190/32   103.249.81.190       GigabitEthernet0/3.39
103.249.81.191/32   receive
103.249.81.192/30   attached             GigabitEthernet0/3.59
103.249.81.192/32   receive
103.249.81.193/32   receive
103.249.81.194/32   103.249.81.194       GigabitEthernet0/3.59
103.249.81.195/32   receive
103.249.81.196/30   attached             GigabitEthernet0/3.183
103.249.81.196/32   receive
103.249.81.197/32   receive
103.249.81.198/32   103.249.81.198       GigabitEthernet0/3.183
103.249.81.199/32   receive
103.249.81.200/30   attached             GigabitEthernet0/3.11
103.249.81.200/32   receive
103.249.81.201/32   receive
103.249.81.202/32   103.249.81.202       GigabitEthernet0/3.11
103.249.81.203/32   receive
103.249.81.204/30   attached             GigabitEthernet0/3.34
103.249.81.204/32   receive
103.249.81.205/32   receive
103.249.81.206/32   103.249.81.206       GigabitEthernet0/3.34
103.249.81.207/32   receive
103.249.81.208/30   attached             GigabitEthernet0/3.40
103.249.81.208/32   receive
103.249.81.209/32   receive
103.249.81.210/32   103.249.81.210       GigabitEthernet0/3.40
103.249.81.211/32   receive
103.249.81.212/30   attached             GigabitEthernet0/3.142
103.249.81.212/32   receive
103.249.81.213/32   receive
103.249.81.214/32   103.249.81.214       GigabitEthernet0/3.142
103.249.81.215/32   receive
103.249.81.216/29   103.249.207.6        GigabitEthernet0/3.801
103.249.81.224/30   103.249.204.30       GigabitEthernet0/3.796
103.249.81.228/30   attached             GigabitEthernet0/3.84
103.249.81.228/32   receive
103.249.81.229/32   receive
103.249.81.231/32   receive
103.249.81.232/30   103.249.204.30       GigabitEthernet0/3.796
103.249.81.236/30   attached             GigabitEthernet0/3.64
103.249.81.236/32   receive
103.249.81.237/32   receive
103.249.81.238/32   103.249.81.238       GigabitEthernet0/3.64
103.249.81.239/32   receive
103.249.82.0/24     attached             Null0
103.249.82.0/30     attached             GigabitEthernet0/3.800
103.249.82.0/32     receive
103.249.82.1/32     receive
103.249.82.3/32     receive
103.249.82.4/30     attached             GigabitEthernet0/3.22
103.249.82.4/32     receive
103.249.82.5/32     receive
103.249.82.6/32     103.249.82.6         GigabitEthernet0/3.22
103.249.82.7/32     receive
103.249.82.8/30     attached             GigabitEthernet0/3.80
103.249.82.8/32     receive
103.249.82.9/32     receive
103.249.82.10/32    103.249.82.10        GigabitEthernet0/3.80
103.249.82.11/32    receive
103.249.82.12/30    103.249.207.6        GigabitEthernet0/3.801
103.249.82.16/30    attached             GigabitEthernet0/3.126
103.249.82.16/32    receive
103.249.82.17/32    receive
103.249.82.18/32    103.249.82.18        GigabitEthernet0/3.126
103.249.82.19/32    receive
103.249.82.20/30    attached             GigabitEthernet0/3.83
103.249.82.20/32    receive
103.249.82.21/32    receive
103.249.82.22/32    103.249.82.22        GigabitEthernet0/3.83
103.249.82.23/32    receive
103.249.82.24/29    attached             GigabitEthernet0/3.190
103.249.82.24/32    receive
103.249.82.25/32    receive
103.249.82.26/32    103.249.82.26        GigabitEthernet0/3.190
103.249.82.31/32    receive
103.249.82.36/30    attached             GigabitEthernet0/3.26
103.249.82.36/32    receive
103.249.82.37/32    receive
103.249.82.38/32    103.249.82.38        GigabitEthernet0/3.26
103.249.82.39/32    receive
103.249.82.52/30    103.249.204.30       GigabitEthernet0/3.796
                    103.249.82.174       GigabitEthernet0/3.170
103.249.82.56/30    attached             GigabitEthernet0/3.99
103.249.82.56/32    receive
103.249.82.57/32    receive
103.249.82.59/32    receive
103.249.82.64/30    attached             GigabitEthernet0/3.10
103.249.82.64/32    receive
103.249.82.65/32    receive
103.249.82.66/32    103.249.82.66        GigabitEthernet0/3.10
103.249.82.67/32    receive
103.249.82.68/30    attached             GigabitEthernet0/3.29
103.249.82.68/32    receive
103.249.82.69/32    receive
103.249.82.70/32    103.249.82.70        GigabitEthernet0/3.29
103.249.82.71/32    receive
103.249.82.72/30    attached             GigabitEthernet0/3.18
103.249.82.72/32    receive
103.249.82.73/32    receive
103.249.82.74/32    103.249.82.74        GigabitEthernet0/3.18
103.249.82.75/32    receive
103.249.82.76/30    attached             GigabitEthernet0/3.23
103.249.82.76/32    receive
103.249.82.77/32    receive
103.249.82.78/32    103.249.82.78        GigabitEthernet0/3.23
103.249.82.79/32    receive
103.249.82.80/30    103.249.207.6        GigabitEthernet0/3.801
103.249.82.84/30    attached             GigabitEthernet0/3.94
103.249.82.84/32    receive
103.249.82.85/32    receive
103.249.82.86/32    103.249.82.86        GigabitEthernet0/3.94
103.249.82.87/32    receive
103.249.82.88/30    attached             GigabitEthernet0/3.181
103.249.82.88/32    receive
103.249.82.89/32    receive
103.249.82.90/32    103.249.82.90        GigabitEthernet0/3.181
103.249.82.91/32    receive
103.249.82.92/30    attached             GigabitEthernet0/3.449
103.249.82.92/32    receive
103.249.82.93/32    receive
103.249.82.94/32    103.249.82.94        GigabitEthernet0/3.449
103.249.82.95/32    receive
103.249.82.96/30    attached             GigabitEthernet0/3.91
103.249.82.96/32    receive
103.249.82.97/32    receive
103.249.82.98/32    103.249.82.98        GigabitEthernet0/3.91
103.249.82.99/32    receive
103.249.82.100/30   attached             GigabitEthernet0/3.119
103.249.82.100/32   receive
103.249.82.101/32   receive
103.249.82.102/32   103.249.82.102       GigabitEthernet0/3.119
103.249.82.103/32   receive
103.249.82.104/30   103.249.80.146       GigabitEthernet0/3.400
103.249.82.108/30   attached             GigabitEthernet0/3.150
103.249.82.108/32   receive
103.249.82.109/32   receive
103.249.82.110/32   103.249.82.110       GigabitEthernet0/3.150
103.249.82.111/32   receive
103.249.82.112/30   attached             GigabitEthernet0/3.75
103.249.82.112/32   receive
103.249.82.113/32   receive
103.249.82.114/32   103.249.82.114       GigabitEthernet0/3.75
103.249.82.115/32   receive
103.249.82.116/30   103.249.204.30       GigabitEthernet0/3.796
103.249.82.120/29   attached             GigabitEthernet0/3.70
103.249.82.120/32   receive
103.249.82.121/32   receive
103.249.82.122/32   103.249.82.122       GigabitEthernet0/3.70
103.249.82.123/32   103.249.82.123       GigabitEthernet0/3.70
103.249.82.124/32   103.249.82.124       GigabitEthernet0/3.70
103.249.82.125/32   103.249.82.125       GigabitEthernet0/3.70
103.249.82.126/32   103.249.82.126       GigabitEthernet0/3.70
103.249.82.127/32   receive
103.249.82.128/28   103.249.204.30       GigabitEthernet0/3.796
103.249.82.144/30   attached             GigabitEthernet0/3.60
103.249.82.144/32   receive
103.249.82.145/32   receive
103.249.82.146/32   103.249.82.146       GigabitEthernet0/3.60
103.249.82.147/32   receive
103.249.82.148/30   attached             GigabitEthernet0/3.107
103.249.82.148/32   receive
103.249.82.149/32   receive
103.249.82.150/32   103.249.82.150       GigabitEthernet0/3.107
103.249.82.151/32   receive
103.249.82.152/30   attached             GigabitEthernet0/3.120
103.249.82.152/32   receive
103.249.82.153/32   receive
103.249.82.154/32   103.249.82.154       GigabitEthernet0/3.120
103.249.82.155/32   receive
103.249.82.156/30   attached             GigabitEthernet0/3.30
103.249.82.156/32   receive
103.249.82.157/32   receive
103.249.82.158/32   103.249.82.158       GigabitEthernet0/3.30
103.249.82.159/32   receive
103.249.82.160/29   attached             GigabitEthernet0/3.48
103.249.82.160/32   receive
103.249.82.161/32   receive
103.249.82.162/32   103.249.82.162       GigabitEthernet0/3.48
103.249.82.163/32   103.249.82.163       GigabitEthernet0/3.48
103.249.82.164/32   103.249.82.164       GigabitEthernet0/3.48
103.249.82.165/32   103.249.82.165       GigabitEthernet0/3.48
103.249.82.166/32   103.249.82.166       GigabitEthernet0/3.48
103.249.82.167/32   receive
103.249.82.168/30   attached             GigabitEthernet0/3.169
103.249.82.168/32   receive
103.249.82.169/32   receive
103.249.82.170/32   103.249.82.170       GigabitEthernet0/3.169
103.249.82.171/32   receive
103.249.82.172/30   103.249.204.30       GigabitEthernet0/3.796
103.249.82.176/29   attached             GigabitEthernet0/3.115
103.249.82.176/32   receive
103.249.82.177/32   receive
103.249.82.178/32   103.249.82.178       GigabitEthernet0/3.115
103.249.82.183/32   receive
103.249.82.184/30   attached             GigabitEthernet0/3.93
103.249.82.184/32   receive
103.249.82.185/32   receive
103.249.82.186/32   103.249.82.186       GigabitEthernet0/3.93
103.249.82.187/32   receive
103.249.82.188/30   attached             GigabitEthernet0/3.42
103.249.82.188/32   receive
103.249.82.189/32   receive
103.249.82.190/32   103.249.82.190       GigabitEthernet0/3.42
103.249.82.191/32   receive
103.249.82.192/29   103.249.81.86        GigabitEthernet0/3.24
103.249.82.200/29   attached             GigabitEthernet0/3.89
103.249.82.200/32   receive
103.249.82.201/32   receive
103.249.82.202/32   103.249.82.202       GigabitEthernet0/3.89
103.249.82.203/32   103.249.82.203       GigabitEthernet0/3.89
103.249.82.207/32   receive
103.249.82.208/28   attached             GigabitEthernet0/3.108
103.249.82.208/32   receive
103.249.82.209/32   receive
103.249.82.210/32   103.249.82.210       GigabitEthernet0/3.108
103.249.82.223/32   receive
103.249.82.224/29   103.249.82.186       GigabitEthernet0/3.93
103.249.82.236/30   attached             GigabitEthernet0/3.450
103.249.82.236/32   receive
103.249.82.237/32   receive
103.249.82.238/32   103.249.82.238       GigabitEthernet0/3.450
103.249.82.239/32   receive
103.249.82.240/29   103.249.82.250       GigabitEthernet0/3.109
103.249.82.248/30   attached             GigabitEthernet0/3.109
103.249.82.248/32   receive
103.249.82.249/32   receive
103.249.82.250/32   103.249.82.250       GigabitEthernet0/3.109
103.249.82.251/32   receive
103.249.82.252/30   attached             GigabitEthernet0/3.140
103.249.82.252/32   receive
103.249.82.253/32   receive
103.249.82.254/32   103.249.82.254       GigabitEthernet0/3.140
103.249.82.255/32   receive
103.249.83.0/24     attached             Null0
103.249.83.0/30     attached             GigabitEthernet0/3.800
103.249.83.0/32     receive
103.249.83.1/32     receive
103.249.83.3/32     receive
103.249.83.4/30     attached             GigabitEthernet0/3.100
103.249.83.4/32     receive
103.249.83.5/32     receive
103.249.83.6/32     103.249.83.6         GigabitEthernet0/3.100
103.249.83.7/32     receive
103.249.83.8/29     103.249.81.14        GigabitEthernet0/3.97
103.249.83.16/28    attached             GigabitEthernet0/3.95
103.249.83.16/32    receive
103.249.83.17/32    receive
103.249.83.18/32    103.249.83.18        GigabitEthernet0/3.95
103.249.83.31/32    receive
103.249.83.40/29    attached             GigabitEthernet0/3.153
103.249.83.40/32    receive
103.249.83.41/32    receive
103.249.83.42/32    103.249.83.42        GigabitEthernet0/3.153
103.249.83.47/32    receive
103.249.83.48/30    103.249.81.110       GigabitEthernet0/3.125
103.249.83.52/30    attached             GigabitEthernet0/3.110
103.249.83.52/32    receive
103.249.83.53/32    receive
103.249.83.54/32    103.249.83.54        GigabitEthernet0/3.110
103.249.83.55/32    receive
103.249.83.56/29    103.249.81.110       GigabitEthernet0/3.125
103.249.83.64/28    103.249.83.6         GigabitEthernet0/3.100
103.249.83.80/28    103.249.83.6         GigabitEthernet0/3.100
103.249.83.96/30    attached             GigabitEthernet0/3.117
103.249.83.96/32    receive
103.249.83.97/32    receive
103.249.83.98/32    103.249.83.98        GigabitEthernet0/3.117
103.249.83.99/32    receive
103.249.83.100/30   attached             GigabitEthernet0/3.118
103.249.83.100/32   receive
103.249.83.101/32   receive
103.249.83.102/32   103.249.83.102       GigabitEthernet0/3.118
103.249.83.103/32   receive
103.249.83.104/29   103.249.204.226      GigabitEthernet0/3.228
103.249.83.112/28   attached             GigabitEthernet0/3.36
103.249.83.112/32   receive
103.249.83.113/32   receive
103.249.83.114/32   103.249.83.114       GigabitEthernet0/3.36
103.249.83.120/32   103.249.83.120       GigabitEthernet0/3.36
103.249.83.127/32   receive
103.249.83.128/29   attached             GigabitEthernet0/3.41
103.249.83.128/32   receive
103.249.83.129/32   receive
103.249.83.130/32   103.249.83.130       GigabitEthernet0/3.41
103.249.83.131/32   103.249.83.131       GigabitEthernet0/3.41
103.249.83.132/32   103.249.83.132       GigabitEthernet0/3.41
103.249.83.135/32   receive
103.249.83.136/30   103.249.207.6        GigabitEthernet0/3.801
103.249.83.140/30   attached             GigabitEthernet0/3.157
103.249.83.140/32   receive
103.249.83.141/32   receive
103.249.83.142/32   103.249.83.142       GigabitEthernet0/3.157
103.249.83.143/32   receive
103.249.83.144/28   103.249.82.38        GigabitEthernet0/3.26
103.249.83.160/29   attached             GigabitEthernet0/3.66
103.249.83.160/32   receive
103.249.83.161/32   receive
103.249.83.162/32   103.249.83.162       GigabitEthernet0/3.66
103.249.83.163/32   103.249.83.163       GigabitEthernet0/3.66
103.249.83.164/32   103.249.83.164       GigabitEthernet0/3.66
103.249.83.167/32   receive
103.249.83.168/30   attached             GigabitEthernet0/3.197
103.249.83.168/32   receive
103.249.83.169/32   receive
103.249.83.170/32   103.249.83.170       GigabitEthernet0/3.197
103.249.83.171/32   receive
103.249.83.172/30   attached             GigabitEthernet0/3.166
103.249.83.172/32   receive
103.249.83.173/32   receive
103.249.83.174/32   103.249.83.174       GigabitEthernet0/3.166
103.249.83.175/32   receive
103.249.83.176/29   attached             GigabitEthernet0/3.129
103.249.83.176/32   receive
103.249.83.177/32   receive
103.249.83.180/32   103.249.83.180       GigabitEthernet0/3.129
103.249.83.181/32   103.249.83.181       GigabitEthernet0/3.129
103.249.83.182/32   103.249.83.182       GigabitEthernet0/3.129
103.249.83.183/32   receive
103.249.83.192/29   attached             GigabitEthernet0/3.134
103.249.83.192/32   receive
103.249.83.193/32   receive
103.249.83.194/32   103.249.83.194       GigabitEthernet0/3.134
103.249.83.199/32   receive
103.249.83.200/30   attached             GigabitEthernet0/3.71
103.249.83.200/32   receive
103.249.83.201/32   receive
103.249.83.202/32   103.249.83.202       GigabitEthernet0/3.71
103.249.83.203/32   receive
103.249.83.204/30   attached             GigabitEthernet0/3.135
103.249.83.204/32   receive
103.249.83.205/32   receive
103.249.83.206/32   103.249.83.206       GigabitEthernet0/3.135
103.249.83.207/32   receive
103.249.83.208/30   103.249.204.30       GigabitEthernet0/3.796
103.249.83.212/30   attached             GigabitEthernet0/3.148
103.249.83.212/32   receive
103.249.83.213/32   receive
103.249.83.214/32   103.249.83.214       GigabitEthernet0/3.148
103.249.83.215/32   receive
103.249.83.216/30   103.249.82.238       GigabitEthernet0/3.450
103.249.83.220/30   attached             GigabitEthernet0/3.90
103.249.83.220/32   receive
103.249.83.221/32   receive
103.249.83.222/32   103.249.83.222       GigabitEthernet0/3.90
103.249.83.223/32   receive
103.249.83.224/30   attached             GigabitEthernet0/3.139
103.249.83.224/32   receive
103.249.83.225/32   receive
103.249.83.226/32   103.249.83.226       GigabitEthernet0/3.139
103.249.83.227/32   receive
103.249.83.228/30   attached             GigabitEthernet0/3.198
103.249.83.228/32   receive
103.249.83.229/32   receive
103.249.83.230/32   103.249.83.230       GigabitEthernet0/3.198
103.249.83.231/32   receive
103.249.83.232/29   attached             GigabitEthernet0/3.149
103.249.83.232/32   receive
103.249.83.233/32   receive
103.249.83.234/32   103.249.83.234       GigabitEthernet0/3.149
103.249.83.235/32   103.249.83.235       GigabitEthernet0/3.149
103.249.83.239/32   receive
103.249.83.240/29   attached             GigabitEthernet0/3.132
103.249.83.240/32   receive
103.249.83.241/32   receive
103.249.83.242/32   103.249.83.242       GigabitEthernet0/3.132
103.249.83.243/32   103.249.83.243       GigabitEthernet0/3.132
103.249.83.247/32   receive
103.249.83.252/30   103.249.204.30       GigabitEthernet0/3.796
103.249.204.0/24    attached             Null0
103.249.204.0/30    attached             GigabitEthernet0/3.800
103.249.204.0/32    receive
103.249.204.1/32    receive
103.249.204.3/32    receive
103.249.204.16/30   attached             GigabitEthernet0/3.205
103.249.204.16/32   receive
103.249.204.17/32   receive
103.249.204.18/32   103.249.204.18       GigabitEthernet0/3.205
103.249.204.19/32   receive
103.249.204.20/30   attached             GigabitEthernet0/3.204
103.249.204.20/32   receive
103.249.204.21/32   receive
103.249.204.22/32   103.249.204.22       GigabitEthernet0/3.204
103.249.204.23/32   receive
103.249.204.28/30   attached             GigabitEthernet0/3.796
103.249.204.28/32   receive
103.249.204.29/32   receive
103.249.204.30/32   103.249.204.30       GigabitEthernet0/3.796
103.249.204.31/32   receive
103.249.204.32/29   103.249.204.42       GigabitEthernet0/3.207
103.249.204.40/30   attached             GigabitEthernet0/3.207
103.249.204.40/32   receive
103.249.204.41/32   receive
103.249.204.42/32   103.249.204.42       GigabitEthernet0/3.207
103.249.204.43/32   receive
103.249.204.44/30   attached             GigabitEthernet0/3.206
103.249.204.44/32   receive
103.249.204.45/32   receive
103.249.204.46/32   103.249.204.46       GigabitEthernet0/3.206
103.249.204.47/32   receive
103.249.204.48/29   103.249.204.46       GigabitEthernet0/3.206
103.249.204.56/30   attached             GigabitEthernet0/3.208
103.249.204.56/32   receive
103.249.204.57/32   receive
103.249.204.58/32   103.249.204.58       GigabitEthernet0/3.208
103.249.204.59/32   receive
103.249.204.60/30   attached             GigabitEthernet0/3.209
103.249.204.60/32   receive
103.249.204.61/32   receive
103.249.204.62/32   103.249.204.62       GigabitEthernet0/3.209
103.249.204.63/32   receive
103.249.204.64/30   attached             GigabitEthernet0/3.210
103.249.204.64/32   receive
103.249.204.65/32   receive
103.249.204.66/32   103.249.204.66       GigabitEthernet0/3.210
103.249.204.67/32   receive
103.249.204.68/30   attached             GigabitEthernet0/3.759
103.249.204.68/32   receive
103.249.204.69/32   receive
103.249.204.70/32   103.249.204.70       GigabitEthernet0/3.759
103.249.204.71/32   receive
103.249.204.72/30   103.249.204.226      GigabitEthernet0/3.228
103.249.204.80/29   attached             GigabitEthernet0/3.225
103.249.204.80/32   receive
103.249.204.81/32   receive
103.249.204.82/32   103.249.204.82       GigabitEthernet0/3.225
103.249.204.87/32   receive
103.249.204.88/30   attached             GigabitEthernet0/3.212
103.249.204.88/32   receive
103.249.204.89/32   receive
103.249.204.90/32   103.249.204.90       GigabitEthernet0/3.212
103.249.204.91/32   receive
103.249.204.92/30   attached             GigabitEthernet0/3.229
103.249.204.92/32   receive
103.249.204.93/32   receive
103.249.204.94/32   103.249.204.94       GigabitEthernet0/3.229
103.249.204.95/32   receive
103.249.204.96/29   attached             GigabitEthernet0/3.222
103.249.204.96/32   receive
103.249.204.97/32   receive
103.249.204.98/32   103.249.204.98       GigabitEthernet0/3.222
103.249.204.99/32   103.249.204.99       GigabitEthernet0/3.222
103.249.204.100/32  103.249.204.100      GigabitEthernet0/3.222
103.249.204.101/32  103.249.204.101      GigabitEthernet0/3.222
103.249.204.102/32  103.249.204.102      GigabitEthernet0/3.222
103.249.204.103/32  receive
103.249.204.104/29  attached             GigabitEthernet0/3.226
103.249.204.104/32  receive
103.249.204.105/32  receive
103.249.204.106/32  103.249.204.106      GigabitEthernet0/3.226
103.249.204.111/32  receive
103.249.204.112/30  attached             GigabitEthernet0/3.219
103.249.204.112/32  receive
103.249.204.113/32  receive
103.249.204.114/32  103.249.204.114      GigabitEthernet0/3.219
103.249.204.115/32  receive
103.249.204.116/30  attached             GigabitEthernet0/3.214
103.249.204.116/32  receive
103.249.204.117/32  receive
103.249.204.118/32  103.249.204.118      GigabitEthernet0/3.214
103.249.204.119/32  receive
103.249.204.120/29  103.249.82.6         GigabitEthernet0/3.22
103.249.204.128/29  103.249.204.118      GigabitEthernet0/3.214
103.249.204.136/29  attached             GigabitEthernet0/3.213
103.249.204.136/32  receive
103.249.204.137/32  receive
103.249.204.138/32  103.249.204.138      GigabitEthernet0/3.213
103.249.204.143/32  receive
103.249.204.144/29  attached             GigabitEthernet0/3.215
103.249.204.144/32  receive
103.249.204.145/32  receive
103.249.204.146/32  103.249.204.146      GigabitEthernet0/3.215
103.249.204.149/32  103.249.204.149      GigabitEthernet0/3.215
103.249.204.151/32  receive
103.249.204.156/30  attached             GigabitEthernet0/3.220
103.249.204.156/32  receive
103.249.204.157/32  receive
103.249.204.158/32  103.249.204.158      GigabitEthernet0/3.220
103.249.204.159/32  receive
103.249.204.160/30  103.249.80.78        GigabitEthernet0/3.67
103.249.204.164/30  attached             GigabitEthernet0/3.230
103.249.204.164/32  receive
103.249.204.165/32  receive
103.249.204.166/32  103.249.204.166      GigabitEthernet0/3.230
103.249.204.167/32  receive
103.249.204.176/29  103.249.207.10       GigabitEthernet0/3.191
103.249.204.184/29  attached             GigabitEthernet0/3.232
103.249.204.184/32  receive
103.249.204.185/32  receive
103.249.204.186/32  103.249.204.186      GigabitEthernet0/3.232
103.249.204.187/32  103.249.204.187      GigabitEthernet0/3.232
103.249.204.189/32  103.249.204.189      GigabitEthernet0/3.232
103.249.204.191/32  receive
103.249.204.192/27  103.249.204.114      GigabitEthernet0/3.219
103.249.204.224/30  attached             GigabitEthernet0/3.228
103.249.204.224/32  receive
103.249.204.225/32  receive
103.249.204.226/32  103.249.204.226      GigabitEthernet0/3.228
103.249.204.227/32  receive
103.249.204.232/29  103.249.204.94       GigabitEthernet0/3.229
103.249.204.240/29  103.249.204.166      GigabitEthernet0/3.230
103.249.204.248/29  attached             GigabitEthernet0/3.231
103.249.204.248/32  receive
103.249.204.249/32  receive
103.249.204.250/32  103.249.204.250      GigabitEthernet0/3.231
103.249.204.255/32  receive
103.249.205.0/24    attached             Null0
103.249.205.0/30    attached             GigabitEthernet0/3.800
103.249.205.0/32    receive
103.249.205.1/32    receive
103.249.205.3/32    receive
103.249.205.4/30    attached             GigabitEthernet0/3.754
103.249.205.4/32    receive
103.249.205.5/32    receive
103.249.205.6/32    103.249.205.6        GigabitEthernet0/3.754
103.249.205.7/32    receive
103.249.205.8/30    103.249.207.6        GigabitEthernet0/3.801
103.249.205.12/30   103.249.207.6        GigabitEthernet0/3.801
103.249.205.16/28   attached             GigabitEthernet0/3.98
103.249.205.16/32   receive
103.249.205.17/32   receive
103.249.205.18/32   103.249.205.18       GigabitEthernet0/3.98
103.249.205.19/32   103.249.205.19       GigabitEthernet0/3.98
103.249.205.20/32   103.249.205.20       GigabitEthernet0/3.98
103.249.205.21/32   103.249.205.21       GigabitEthernet0/3.98
103.249.205.22/32   103.249.205.22       GigabitEthernet0/3.98
103.249.205.23/32   103.249.205.23       GigabitEthernet0/3.98
103.249.205.24/32   103.249.205.24       GigabitEthernet0/3.98
103.249.205.25/32   103.249.205.25       GigabitEthernet0/3.98
103.249.205.26/32   103.249.205.26       GigabitEthernet0/3.98
103.249.205.27/32   103.249.205.27       GigabitEthernet0/3.98
103.249.205.31/32   receive
103.249.205.32/30   attached             GigabitEthernet0/3.798
103.249.205.32/32   receive
103.249.205.33/32   receive
103.249.205.35/32   receive
103.249.205.36/30   attached             GigabitEthernet0/3.185
103.249.205.36/32   receive
103.249.205.37/32   receive
103.249.205.38/32   103.249.205.38       GigabitEthernet0/3.185
103.249.205.39/32   receive
103.249.205.44/30   attached             GigabitEthernet0/3.21
103.249.205.44/32   receive
103.249.205.45/32   receive
103.249.205.46/32   103.249.205.46       GigabitEthernet0/3.21
103.249.205.47/32   receive
103.249.205.48/29   attached             GigabitEthernet0/3.61
103.249.205.48/32   receive
103.249.205.49/32   receive
103.249.205.50/32   103.249.205.50       GigabitEthernet0/3.61
103.249.205.55/32   receive
103.249.205.56/29   103.249.205.198      GigabitEthernet0/3.144
103.249.205.64/29   103.249.207.82       GigabitEthernet0/3.65
103.249.205.72/30   attached             GigabitEthernet0/3.146
103.249.205.72/32   receive
103.249.205.73/32   receive
103.249.205.74/32   103.249.205.74       GigabitEthernet0/3.146
103.249.205.75/32   receive
103.249.205.76/30   attached             GigabitEthernet0/3.186
103.249.205.76/32   receive
103.249.205.77/32   receive
103.249.205.78/32   103.249.205.78       GigabitEthernet0/3.186
103.249.205.79/32   receive
103.249.205.80/30   attached             GigabitEthernet0/3.104
103.249.205.80/32   receive
103.249.205.81/32   receive
103.249.205.82/32   103.249.205.82       GigabitEthernet0/3.104
103.249.205.83/32   receive
103.249.205.84/30   attached             GigabitEthernet0/3.82
103.249.205.84/32   receive
103.249.205.85/32   receive
103.249.205.87/32   receive
103.249.205.88/29   103.249.82.110       GigabitEthernet0/3.150
103.249.205.96/27   103.249.205.46       GigabitEthernet0/3.21
103.249.205.128/29  103.249.82.254       GigabitEthernet0/3.140
103.249.205.136/29  attached             GigabitEthernet0/3.49
103.249.205.136/32  receive
103.249.205.137/32  receive
103.249.205.138/32  103.249.205.138      GigabitEthernet0/3.49
103.249.205.139/32  103.249.205.139      GigabitEthernet0/3.49
103.249.205.141/32  103.249.205.141      GigabitEthernet0/3.49
103.249.205.143/32  receive
103.249.205.144/29  attached             GigabitEthernet0/3.448
103.249.205.144/32  receive
103.249.205.145/32  receive
103.249.205.146/32  103.249.205.146      GigabitEthernet0/3.448
103.249.205.151/32  receive
103.249.205.152/29  103.249.205.82       GigabitEthernet0/3.104
103.249.205.160/29  103.249.80.142       GigabitEthernet0/3.156
103.249.205.168/30  attached             GigabitEthernet0/3.137
103.249.205.168/32  receive
103.249.205.169/32  receive
103.249.205.170/32  103.249.205.170      GigabitEthernet0/3.137
103.249.205.171/32  receive
103.249.205.176/29  103.249.81.186       GigabitEthernet0/3.62
103.249.205.184/29  attached             GigabitEthernet0/3.63
103.249.205.184/32  receive
103.249.205.185/32  receive
103.249.205.186/32  103.249.205.186      GigabitEthernet0/3.63
103.249.205.188/32  103.249.205.188      GigabitEthernet0/3.63
103.249.205.191/32  receive
103.249.205.192/30  attached             GigabitEthernet0/3.111
103.249.205.192/32  receive
103.249.205.193/32  receive
103.249.205.194/32  103.249.205.194      GigabitEthernet0/3.111
103.249.205.195/32  receive
103.249.205.196/30  attached             GigabitEthernet0/3.144
103.249.205.196/32  receive
103.249.205.197/32  receive
103.249.205.198/32  103.249.205.198      GigabitEthernet0/3.144
103.249.205.199/32  receive
103.249.205.200/29  attached             GigabitEthernet0/3.758
103.249.205.200/32  receive
103.249.205.201/32  receive
103.249.205.203/32  103.249.205.203      GigabitEthernet0/3.758
103.249.205.204/32  103.249.205.204      GigabitEthernet0/3.758
103.249.205.205/32  103.249.205.205      GigabitEthernet0/3.758
103.249.205.207/32  receive
103.249.205.208/30  attached             GigabitEthernet0/3.159
103.249.205.208/32  receive
103.249.205.209/32  receive
103.249.205.210/32  103.249.205.210      GigabitEthernet0/3.159
103.249.205.211/32  receive
103.249.205.212/30  attached             GigabitEthernet0/3.81
103.249.205.212/32  receive
103.249.205.213/32  receive
103.249.205.214/32  103.249.205.214      GigabitEthernet0/3.81
103.249.205.215/32  receive
103.249.205.224/29  attached             GigabitEthernet0/3.28
103.249.205.224/32  receive
103.249.205.225/32  receive
103.249.205.226/32  103.249.205.226      GigabitEthernet0/3.28
103.249.205.228/32  103.249.205.228      GigabitEthernet0/3.28
103.249.205.231/32  receive
103.249.205.232/30  attached             GigabitEthernet0/3.160
103.249.205.232/32  receive
103.249.205.233/32  receive
103.249.205.234/32  103.249.205.234      GigabitEthernet0/3.160
103.249.205.235/32  receive
103.249.205.236/30  attached             GigabitEthernet0/3.161
103.249.205.236/32  receive
103.249.205.237/32  receive
103.249.205.238/32  103.249.205.238      GigabitEthernet0/3.161
103.249.205.239/32  receive
103.249.205.240/30  attached             GigabitEthernet0/3.162
103.249.205.240/32  receive
103.249.205.241/32  receive
103.249.205.242/32  103.249.205.242      GigabitEthernet0/3.162
103.249.205.243/32  receive
103.249.205.244/30  attached             GigabitEthernet0/3.164
103.249.205.244/32  receive
103.249.205.245/32  receive
103.249.205.246/32  103.249.205.246      GigabitEthernet0/3.164
103.249.205.247/32  receive
103.249.205.248/29  attached             GigabitEthernet0/3.227
103.249.205.248/32  receive
103.249.205.249/32  receive
103.249.205.250/32  103.249.205.250      GigabitEthernet0/3.227
103.249.205.255/32  receive
103.249.206.0/24    attached             Null0
103.249.206.0/30    attached             GigabitEthernet0/3.800
103.249.206.0/32    receive
103.249.206.1/32    receive
103.249.206.3/32    receive
103.249.206.4/30    103.249.207.6        GigabitEthernet0/3.801
103.249.206.8/30    attached             GigabitEthernet0/3.58
103.249.206.8/32    receive
103.249.206.9/32    receive
103.249.206.10/32   103.249.206.10       GigabitEthernet0/3.58
103.249.206.11/32   receive
103.249.206.16/29   attached             GigabitEthernet0/3.17
103.249.206.16/32   receive
103.249.206.17/32   receive
103.249.206.18/32   103.249.206.18       GigabitEthernet0/3.17
103.249.206.23/32   receive
103.249.206.24/30   attached             GigabitEthernet0/3.27
103.249.206.24/32   receive
103.249.206.25/32   receive
103.249.206.26/32   103.249.206.26       GigabitEthernet0/3.27
103.249.206.27/32   receive
103.249.206.28/30   103.249.204.30       GigabitEthernet0/3.796
103.249.206.44/30   attached             GigabitEthernet0/3.38
103.249.206.44/32   receive
103.249.206.45/32   receive
103.249.206.46/32   103.249.206.46       GigabitEthernet0/3.38
103.249.206.47/32   receive
103.249.206.48/29   attached             GigabitEthernet0/3.16
103.249.206.48/32   receive
103.249.206.49/32   receive
103.249.206.50/32   103.249.206.50       GigabitEthernet0/3.16
103.249.206.51/32   103.249.206.51       GigabitEthernet0/3.16
103.249.206.52/32   103.249.206.52       GigabitEthernet0/3.16
103.249.206.53/32   103.249.206.53       GigabitEthernet0/3.16
103.249.206.55/32   receive
103.249.206.56/29   103.249.83.202       GigabitEthernet0/3.71
103.249.206.64/28   103.249.205.210      GigabitEthernet0/3.159
103.249.206.80/29   attached             GigabitEthernet0/3.172
103.249.206.80/32   receive
103.249.206.81/32   receive
103.249.206.82/32   103.249.206.82       GigabitEthernet0/3.172
103.249.206.83/32   103.249.206.83       GigabitEthernet0/3.172
103.249.206.84/32   103.249.206.84       GigabitEthernet0/3.172
103.249.206.85/32   103.249.206.85       GigabitEthernet0/3.172
103.249.206.87/32   receive
103.249.206.88/29   attached             GigabitEthernet0/3.173
103.249.206.88/32   receive
103.249.206.89/32   receive
103.249.206.90/32   103.249.206.90       GigabitEthernet0/3.173
103.249.206.91/32   103.249.206.91       GigabitEthernet0/3.173
103.249.206.95/32   receive
103.249.206.96/28   attached             GigabitEthernet0/3.168
103.249.206.96/32   receive
103.249.206.97/32   receive
103.249.206.100/32  103.249.206.100      GigabitEthernet0/3.168
103.249.206.101/32  103.249.206.101      GigabitEthernet0/3.168
103.249.206.102/32  103.249.206.102      GigabitEthernet0/3.168
103.249.206.103/32  103.249.206.103      GigabitEthernet0/3.168
103.249.206.104/32  103.249.206.104      GigabitEthernet0/3.168
103.249.206.111/32  receive
103.249.206.112/29  103.249.205.214      GigabitEthernet0/3.81
103.249.206.120/29  attached             GigabitEthernet0/3.175
103.249.206.120/32  receive
103.249.206.121/32  receive
103.249.206.122/32  103.249.206.122      GigabitEthernet0/3.175
103.249.206.127/32  receive
103.249.206.128/30  attached             GigabitEthernet0/3.176
103.249.206.128/32  receive
103.249.206.129/32  receive
103.249.206.130/32  103.249.206.130      GigabitEthernet0/3.176
103.249.206.131/32  receive
103.249.206.132/30  attached             GigabitEthernet0/3.211
103.249.206.132/32  receive
103.249.206.133/32  receive
103.249.206.134/32  103.249.206.134      GigabitEthernet0/3.211
103.249.206.135/32  receive
103.249.206.136/30  103.249.204.30       GigabitEthernet0/3.796
103.249.206.140/30  attached             GigabitEthernet0/3.102
103.249.206.140/32  receive
103.249.206.141/32  receive
103.249.206.142/32  103.249.206.142      GigabitEthernet0/3.102
103.249.206.143/32  receive
103.249.206.152/30  attached             GigabitEthernet0/3.47
103.249.206.152/32  receive
103.249.206.153/32  receive
103.249.206.154/32  103.249.206.154      GigabitEthernet0/3.47
103.249.206.155/32  receive
103.249.206.156/30  attached             GigabitEthernet0/3.165
103.249.206.156/32  receive
103.249.206.157/32  receive
103.249.206.158/32  103.249.206.158      GigabitEthernet0/3.165
103.249.206.159/32  receive
103.249.206.160/29  attached             GigabitEthernet0/3.195
103.249.206.160/32  receive
103.249.206.161/32  receive
103.249.206.167/32  receive
103.249.206.168/29  attached             GigabitEthernet0/3.103
103.249.206.168/32  receive
103.249.206.169/32  receive
103.249.206.171/32  103.249.206.171      GigabitEthernet0/3.103
103.249.206.175/32  receive
103.249.206.176/29  attached             GigabitEthernet0/3.221
103.249.206.176/32  receive
103.249.206.177/32  receive
103.249.206.178/32  103.249.206.178      GigabitEthernet0/3.221
103.249.206.179/32  103.249.206.179      GigabitEthernet0/3.221
103.249.206.180/32  103.249.206.180      GigabitEthernet0/3.221
103.249.206.181/32  103.249.206.181      GigabitEthernet0/3.221
103.249.206.183/32  receive
103.249.206.184/30  attached             GigabitEthernet0/3.233
103.249.206.184/32  receive
103.249.206.185/32  receive
103.249.206.187/32  receive
103.249.206.188/30  attached             GigabitEthernet0/3.234
103.249.206.188/32  receive
103.249.206.189/32  receive
103.249.206.191/32  receive
103.249.206.192/29  attached             GigabitEthernet0/3.124
103.249.206.192/32  receive
103.249.206.193/32  receive
103.249.206.194/32  103.249.206.194      GigabitEthernet0/3.124
103.249.206.198/32  103.249.206.198      GigabitEthernet0/3.124
103.249.206.199/32  receive
103.249.206.200/30  attached             GigabitEthernet0/3.74
103.249.206.200/32  receive
103.249.206.201/32  receive
103.249.206.202/32  103.249.206.202      GigabitEthernet0/3.74
103.249.206.203/32  receive
103.249.206.204/30  attached             GigabitEthernet0/3.756
103.249.206.204/32  receive
103.249.206.205/32  receive
103.249.206.207/32  receive
103.249.206.208/28  attached             GigabitEthernet0/3.77
103.249.206.208/32  receive
103.249.206.209/32  receive
103.249.206.223/32  receive
103.249.206.248/29  103.249.206.158      GigabitEthernet0/3.165
103.249.207.0/24    attached             Null0
103.249.207.0/30    attached             GigabitEthernet0/3.800
103.249.207.0/32    receive
103.249.207.1/32    receive
103.249.207.3/32    receive
103.249.207.4/30    attached             GigabitEthernet0/3.801
103.249.207.4/32    receive
103.249.207.5/32    receive
103.249.207.6/32    103.249.207.6        GigabitEthernet0/3.801
103.249.207.7/32    receive
103.249.207.8/30    attached             GigabitEthernet0/3.191
103.249.207.8/32    receive
103.249.207.9/32    receive
103.249.207.10/32   103.249.207.10       GigabitEthernet0/3.191
103.249.207.11/32   receive
103.249.207.12/30   attached             GigabitEthernet0/3.72
103.249.207.12/32   receive
103.249.207.13/32   receive
103.249.207.15/32   receive
103.249.207.20/30   attached             GigabitEthernet0/3.180
103.249.207.20/32   receive
103.249.207.21/32   receive
103.249.207.22/32   103.249.207.22       GigabitEthernet0/3.180
103.249.207.23/32   receive
103.249.207.24/30   103.249.81.206       GigabitEthernet0/3.34
103.249.207.28/30   attached             GigabitEthernet0/3.304
103.249.207.28/32   receive
103.249.207.29/32   receive
103.249.207.30/32   103.249.207.30       GigabitEthernet0/3.304
103.249.207.31/32   receive
103.249.207.32/27   103.249.207.10       GigabitEthernet0/3.191
103.249.207.64/28   103.249.207.30       GigabitEthernet0/3.304
103.249.207.80/30   attached             GigabitEthernet0/3.65
103.249.207.80/32   receive
103.249.207.81/32   receive
103.249.207.82/32   103.249.207.82       GigabitEthernet0/3.65
103.249.207.83/32   receive
103.249.207.84/30   attached             GigabitEthernet0/3.69
103.249.207.84/32   receive
103.249.207.85/32   receive
103.249.207.86/32   103.249.207.86       GigabitEthernet0/3.69
103.249.207.87/32   receive
103.249.207.88/30   attached             GigabitEthernet0/3.800
103.249.207.88/32   receive
103.249.207.89/32   receive
103.249.207.91/32   receive
103.249.207.96/27   103.249.207.22       GigabitEthernet0/3.180
103.249.207.128/29  attached             GigabitEthernet0/3.174
103.249.207.128/32  receive
103.249.207.129/32  receive
103.249.207.130/32  103.249.207.130      GigabitEthernet0/3.174
103.249.207.131/32  103.249.207.131      GigabitEthernet0/3.174
103.249.207.133/32  103.249.207.133      GigabitEthernet0/3.174
103.249.207.135/32  receive
103.249.207.136/30  103.249.204.30       GigabitEthernet0/3.796
103.249.207.144/29  attached             GigabitEthernet0/3.147
103.249.207.144/32  receive
103.249.207.145/32  receive
103.249.207.151/32  receive
103.249.207.152/30  attached             GigabitEthernet0/3.154
103.249.207.152/32  receive
103.249.207.153/32  receive
103.249.207.155/32  receive
103.249.207.156/30  attached             GigabitEthernet0/3.170
103.249.207.156/32  receive
103.249.207.157/32  receive
103.249.207.159/32  receive
103.249.207.160/29  103.249.207.82       GigabitEthernet0/3.65
103.249.207.176/30  attached             GigabitEthernet0/3.199
103.249.207.176/32  receive
103.249.207.177/32  receive
103.249.207.179/32  receive
103.249.207.184/30  attached             GigabitEthernet0/3.200
103.249.207.184/32  receive
103.249.207.185/32  receive
103.249.207.187/32  receive
103.249.207.188/30  attached             GigabitEthernet0/3.201
103.249.207.188/32  receive
103.249.207.189/32  receive
103.249.207.190/32  103.249.207.190      GigabitEthernet0/3.201
103.249.207.191/32  receive
103.249.207.192/26  103.249.207.22       GigabitEthernet0/3.180
115.248.4.220/30    attached             GigabitEthernet0/2
115.248.4.220/32    receive
115.248.4.221/32    receive
115.248.4.222/32    115.248.4.222        GigabitEthernet0/2
115.248.4.223/32    receive
119.35.29.46/32     attached             Null0
124.124.201.136/32  attached             Null0
124.124.201.154/32  attached             Null0
124.124.201.178/32  attached             Null0
124.124.201.198/32  attached             Null0
124.124.201.215/32  attached             Null0
184.26.162.81/32    attached             Null0
184.26.162.83/32    attached             Null0
184.26.162.88/32    attached             Null0
184.26.162.90/32    attached             Null0
184.26.162.96/32    attached             Null0
224.0.0.0/4         drop
224.0.0.0/24        receive
255.255.255.255/32  receive
NOC#sh ip cef gigabitEthernet 0/1  detail
IP CEF with switching (Table Version 4563781), flags=0x0
  1270 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 22
  196 instant recursive resolutions, 0 used background process
  1270 leaves, 56 nodes, 251336 bytes, 4563687 inserts, 4562417 invalidations
  1 load sharing elements, 376 bytes, 1 references
  universal per-destination load sharing algorithm, id FE45E983
  3(0) CEF resets, 1 revisions of existing leaves
  Resolution Timer: Exponential (currently 1s, peak 2s)
  1 in-place/0 aborted modifications
  refcounts:  19378 leaf, 14592 node
  Table epoch: 0 (1270 entries at this epoch)
Adjacency Table has 257 adjacencies
  1 IPv4 incomplete adjacency
0.0.0.0/0, version 2117282, epoch 0, cached adjacency 27.251.112.161
0 packets, 0 bytes
  Flow: AS 0, mask 0
  via 27.251.112.161, 0 dependencies, recursive
    next hop 27.251.112.161, GigabitEthernet0/1 via 27.251.112.161/32
    valid cached adjacency
27.251.112.160/30, version 43, epoch 0, attached, connected
0 packets, 0 bytes
  Flow: AS 0, mask 30
  via GigabitEthernet0/1, 0 dependencies
    valid glean adjacency
27.251.112.161/32, version 4136982, epoch 0, connected, cached adjacency 27.251.112.161
0 packets, 0 bytes
  Flow: AS 0, mask 30
  via 27.251.112.161, GigabitEthernet0/1, 1 dependency
NOC#
NOC#sh ip cef gigabitEthernet 0/2  detail
23.96.112.53/32, version 2731716, epoch 0, cached adjacency 115.248.4.222
0 packets, 0 bytes
  Flow: AS 0, mask 32
  via 115.248.4.222, 0 dependencies, recursive
    next hop 115.248.4.222, GigabitEthernet0/2 via 115.248.4.222/32
50.16.217.194/32, version 48, epoch 0, cached adjacency 115.248.4.222
0 packets, 0 bytes
  Flow: AS 0, mask 32
64.29.151.221/32, version 49, epoch 0, cached adjacency 115.248.4.222
0 packets, 0 bytes
  Flow: AS 0, mask 32
64.79.161.110/32, version 50, epoch 0, cached adjacency 115.248.4.222
0 packets, 0 bytes
  Flow: AS 0, mask 32
94.205.250.164/32, version 1494720, epoch 0, cached adjacency 115.248.4.222
0 packets, 0 bytes
  Flow: AS 0, mask 32
115.248.4.220/30, version 47, epoch 0, attached, connected
0 packets, 0 bytes
  Flow: AS 0, mask 30
  via GigabitEthernet0/2, 0 dependencies
115.248.4.222/32, version 4137007, epoch 0, connected, cached adjacency 115.248.4.222
0 packets, 0 bytes
  Flow: AS 0, mask 30
  via 115.248.4.222, GigabitEthernet0/2, 5 dependencies
NOC#sh ip cef gigabitEthernet 0/3  detail
IP CEF with switching (Table Version 4564032), flags=0x0
  1271 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 22
  1271 leaves, 56 nodes, 251488 bytes, 4563938 inserts, 4562667 invalidations
  refcounts:  19382 leaf, 14592 node
  Table epoch: 0 (1271 entries at this epoch)
Adjacency Table has 258 adjacencies
