RADIO INTERFACE FLAPS VERY OFTEN!
Dear All,
I have an issue with a LAP: cisco AIR-LAP1242AG-E-K9
Using the IOS: System image file is "flash:/c1240-k9w8-mx.124-25e.JAO6/c1240-k9w8-mx.124-25e.JAO6"
LAP#sh controllers dot11Radio 0 | i reset
Driver TX blocks: in use 0, high 0, at reset 0, fail 0 drop 0
Last radio reset code: 62
Radio resets - total:21 retries:0 failed:0
LAP#sh controllers dot11Radio 1 | i reset
Last radio reset code: 37
Radio resets - total:17 retries:0 failed:0
LAP#
I have the above issue, and my radio interface keeps bouncing randomly:
62 RADIO_RC_SET_CHANNEL Radio channel set. Reset while setting channel from Control and Provisioning of Wireless Access Points (CAPWAP).
37 RADIO_RC_IDB_RESET Radio interface reset.
LAP#sh log | i adio
*Mar  1 00:00:07.471: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:08.930: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Dec 13 00:58:52.268: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 13 00:58:52.268: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 13 00:58:52.504: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec 13 00:58:52.504: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Dec 13 00:58:53.268: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec 13 00:58:53.268: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec 13 00:58:53.809: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 13 00:58:54.809: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec 13 00:58:54.848: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 13 00:58:55.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun  2 07:54:18.816: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun  2 07:54:18.818: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun  2 07:54:19.792: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun  2 07:54:20.058: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun  2 07:54:20.062: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Jun  2 07:54:20.067: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jun  2 07:54:21.185: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun  2 07:54:21.185: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jun  2 07:54:21.330: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun  2 07:54:21.339: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun  2 07:54:21.344: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun  2 07:54:22.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jun  2 07:54:22.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun  2 07:54:22.438: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun  2 07:54:22.444: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Jun  2 07:54:22.449: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jun  2 07:54:23.494: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun  2 07:54:23.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jun  2 07:54:23.728: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun  2 07:54:24.801: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jun  4 12:15:40.633: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun  4 12:15:40.635: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun  4 12:15:41.632: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun  4 12:15:41.658: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun  4 12:15:42.658: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
LAP#
I tried to reload the LAP, but had no effect on the fault. I tried to find some more info on cisco forums about the codes or how to remedy them but I could not get anyfurther.
Please let me know if you have any ideas.
Best Regards
Leo Laohoo
What firmware is the controller running on and post the screenshot for the settings for DCA.
the WLC is a 5500 running on: 7.6.130.0
The screenshots are attached.
Please note that there is an exact same AP on site which works perfectly.
Best Regards
Hi Guys
Had this issue been solved? How?
My problem is very similar to this. If you can share the method, I will be appreciate.
