Radius Server DEAD and ALIVE Problem
Mehmet Can
Hello All,
I want to ask about after ISE integration. I provisioned our 2 Border Switch but i'm getting a lot of error messages about ISE. What's the problem? In version 16.9.3 I don't get this error. How can I solve this problem?
I don't configure aaa and radius configuration manualy. All configuration created by DNA Center.
Versions:
SW: 9500-16X - 16.11.1c
DNA: 1.3.1.4
Jan 16 2020 04:37:05.642 UTC: %RADIUS-6-SERVERALIVE: Group dnac-client-radius-group: Radius server X.X.X.X:1812,1813 is responding again (previously dead).
Jan 16 2020 04:37:05.642 UTC: %RADIUS-4-RADIUS_ALIVE: RADIUS server X.X.X.X:1812,1813 is being marked alive.
Jan 16 2020 04:37:06.510 UTC: %RADIUS-4-RADIUS_DEAD: RADIUS server X.X.X.X:1812,1813 is not responding.
Jan 16 2020 04:37:22.250 UTC: %CTS-3-AAA_NO_RADIUS_SERVER: No RADIUS servers available for CTS AAA request for CTS env-data SM
Jan 16 2020 04:37:26.654 UTC: %RADIUS-3-ALLDEADSERVER: Group dnac-network-radius-group: No active radius servers found. Id 177.
Jan 16 2020 04:38:49.996 UTC: %RADIUS-6-SERVERALIVE: Group dnac-network-radius-group: Radius server Y.Y.Y.Y:1812,1813 is responding again (previously dead).
Jan 16 2020 04:38:49.996 UTC: %RADIUS-4-RADIUS_ALIVE: RADIUS server Y.Y.Y.Y:1812,1813 is being marked alive.
Jan 16 2020 04:39:34.352 UTC: %RADIUS-4-RADIUS_DEAD: RADIUS server Y.Y.Y.Y:1812,1813 is not responding.
Jan 16 2020 04:40:06.509 UTC: %RADIUS-4-RADIUS_ALIVE: RADIUS server X.X.X.X:1812,1813 is being marked alive.
Jan 16 2020 04:41:18.708 UTC: %RADIUS-4-RADIUS_DEAD: RADIUS server X.X.X.X:1812,1813 is not responding.
Jan 16 2020 04:41:50.966 UTC: %RADIUS-3-ALLDEADSERVER: Group dnac-client-radius-group: No active radius servers found. Id 146.
Jan 16 2020 04:42:34.352 UTC: %RADIUS-6-SERVERALIVE: Group dnac-client-radius-group: Radius server Y.Y.Y.Y:1812,1813 is responding again (previously dead).
Jan 16 2020 04:42:34.352 UTC: %RADIUS-4-RADIUS_ALIVE: RADIUS server Y.Y.Y.Y:1812,1813 is being marked alive.
Jan 16 2020 04:42:45.520 UTC: %RADIUS-4-RADIUS_DEAD: RADIUS server Y.Y.Y.Y:1812,1813 is not responding.
Jan 16 2020 04:42:45.520 UTC: %RADIUS-3-ALLDEADSERVER: Group dnac-network-radius-group: No active radius servers found. Id 188.
Jan 16 2020 04:42:50.967 UTC: %CTS-3-AAA_NO_RADIUS_SERVER: No RADIUS servers available for CTS AAA request for CTS env-data SM
Jan 16 2020 04:44:18.708 UTC: %RADIUS-6-SERVERALIVE: Group dnac-network-radius-group: Radius server X.X.X.X:1812,1813 is responding again (previously dead).
Jan 16 2020 04:44:18.708 UTC: %RADIUS-4-RADIUS_ALIVE: RADIUS server X.X.X.X:1812,1813 is being marked alive.
Radius Conf.
aaa group server radius dnac-client-radius-group
 server name dnac-radius_X.X.X.X
 server name dnac-radius_Y.Y.Y.Y
 ip radius source-interface Loopback0
aaa group server radius dnac-network-radius-group
aaa authentication login dnac-cts-list group dnac-client-radius-group local
aaa authentication login VTY_authen group dnac-network-radius-group local
aaa authentication dot1x default group dnac-client-radius-group
aaa authorization exec VTY_author group dnac-network-radius-group local if-authenticated
aaa authorization network default group dnac-client-radius-group
aaa authorization network dnac-cts-list group dnac-client-radius-group
aaa accounting identity default start-stop group dnac-client-radius-group
aaa accounting exec default start-stop group dnac-network-radius-group
aaa server radius dynamic-author
 client X.X.X.X server-key 7 PRE-SHARED-KEY
 client Y.Y.Y.Y server-key 7 PRE-SHARED-KEY
radius-server attribute 6 on-for-login-auth
radius-server attribute 6 support-multiple
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server attribute 31 mac format ietf upper-case
radius-server attribute 31 send nas-port-detail mac-only
radius-server dead-criteria time 5 tries 3
radius-server deadtime 3
radius server dnac-radius_X.X.X.X
 address ipv4 X.X.X.X auth-port 1812 acct-port 1813
 timeout 4
 retransmit 3
 pac key 7 PRE-SHARED-KEY
radius server dnac-radius_Y.Y.Y.Y
 address ipv4 Y.Y.Y.Y auth-port 1812 acct-port 1813
 timeout 4
 retransmit 3
Mehmet Can
I resolved this issue. My problem is our internal firewall doing NAT our RLOC IP from in to out way. When i delete our RLOC IP Block from NAT Pool everything was fine How could i see? I got packet captures from edge switch uplink ports.
10 Replies 10
soporte.sona
Hello
I have the same issue, i have 3 edge devices with the same problem. did you find a solution?
regards,
   Is there UDP 1812/1813, 1645/1646 between the NAD and ISE, and is also ISE configured? This seems to be the problem from those logs. What exact problem re you experiencing?
Cristian Matei.
I have an open Case on this. The ISE team is continuing to work on the issue. I will share information when I get an answer.
hello,
I have the same behaviour with Catalyst 9300.
OK with version 16.9.3
Pb with version 16.9.4
I don't have the solution but I have isolated the command which involves this issue :
cts authorization list <cts-list>
Because I don't use trustsec now, I have removed this command in order to avoid polluting logs.
Hi, you got any update from Cisco on this case?
you will not believe it, but the case has been open for 3 months. There is still no further improvement.
Emre Ozel
hi,
I shared a few things about the issue solution. I recommend you to look.
https://community.cisco.com/t5/switching/detect-up-down-radius-server/m-p/4145622/highlight/true#M492353
alvarteearu
Had a same issue, even when I completely blocked RADIUS access with Firewall, it kept popping up as alive.
The solution or maybe we can also call it a workaround, was “automate-tester” and “probe-on” function that is available from IOS 15.2(2)E / XE 03.04.00E. With this addition “dead” server will be marked “up” only when a response is received from the RADIUS server, hence as I actually did not get responses back from the server, it was kept “dead”.
Mehmet Can
@Mehmet Can  How did discover the RLOC IP in NAT ?
