Rapid-pvst still taking 30secs to converge
Matthew Lucas
Guys,
I'm a little confused here. I've set all my switches (mix of 3750X, 2960S & CG and 3560CG) to rapid-pvst, yet whenever I plug in a new device, it still takes 30 secs for the switch to start allowing communications. My understanding was that rapid-pvst is a variation on rstp, which should take 3 seconds to converge.
The syntax I've used is:
#spanning-tree mode rapid-pvst
Have I missed anything?
Thanks in advance,
Matt
As suggested above, you need to configure portfast. Access port is independant from the rest of Rapid STP features.
Hello
when you say "plug in a new device" do you mean into an access port? If so - Do you have portfast enabled?
Sh span summary
Res
Paul
Please don't forget to rate any post that may have been helpful
Kind Regards
Paul
Paul - yes, into an access port, and no, I don't have portfast enabled (that was intentional, but I'm open to suggestions).
ASW24#sh span summary
Switch is in rapid-pvst mode
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Configured Pathcost method used is short
Name                   Blocking Listening Learning Forwarding STP Active
VLAN0001                     1         0        0          1          2
VLAN0004                     1         0        0          1          2
VLAN0008                     1         0        0          1          2
VLAN0016                     1         0        0          1          2
VLAN0020                     1         0        0          1          2
VLAN0024                     1         0        0          1          2
VLAN0028                     1         0        0          1          2
VLAN0032                     1         0        0          1          2
VLAN0036                     1         0        0          1          2
VLAN0244                     1         0        0          1          2
VLAN0248                     1         0        0          1          2
VLAN0252                     1         0        0          1          2
12 vlans                    12         0        0         12         24
ASW24#
Ok, fair enough. That solves that question, haha. I've got another issue which I'll start a new thread for too. Thanks very much guys.
